Reply 6060 of 7807, by Joseph_Joestar
Over the past week or so, I completed another run through Doom 1 and Doom 2, but this time on the "Ultra Violence" difficulty setting. Not sure why I didn't try this sooner, it was super fun. The original Doom was very manageable on UV, with only the first one or two of levels of each episode being somewhat irksome, until you find your staple weapons and sufficient ammo. For the most part, this game does provide enough resources to deal with the extra enemies that appear on UV, but I did find myself using the chainsaw and berserk fist slightly more than usual, in an effort to conserve ammo.
Doom 2 suffered a bit more from ammo scarcity on UV, especially in certain levels like Refueling Base. I had to rely on the chainsaw and berserk a fair bit during the ammo starved levels. Thankfully, they weren't too frequent, and you could stock up on some of the more plentiful maps to build up a reserve for later. It also helps to discover every single secret. I did find a few of Doom 2's ambushes on UV a bit tiresome, mostly due to the frequent placement of hitscan enemies beyond the player's line of sight (i.e. far above you). I still had a good time overall, but it wasn't always as fun as the original Doom.
Lastly, I also played through the No Rest for the Living expansion for Doom 2. From my experience, its levels were perfectly balanced for UV, providing just enough ammo to dish out some serious pain to the extra enemies, while still keeping the game very challenging and fun. Honestly, I liked the expansion content more than certain levels from the original Doom 2 campaign. The maps are filled with tough (but fair) combat encounters, interesting secrets and cool visuals. Most importantly, they don't use any silly gimmicks that the base Doom 2 campaign was (in)famous for.
If I had to find one super minor thing to nitpick about, it would be that the expansion doesn't provide you with a backpack (for increased ammo capacity) until the final level. But to be honest, this didn't cause any issues during my UV run, as the ammo distribution is nicely balanced for each level, so you don't have to save up as much as in vanilla Doom 2. Overall, I'd say that No Rest for the Living was the highlight of my UV playthrough, and I can highly recommend it. From all of the official expansions for the classic Doom games, this one is definitively my favorite.
My retro builds
Reply 6061 of 7807, by ncmark
Half-life blue shift
Reply 6062 of 7807, by StriderTR
Been playing a lot of an old favorite recently, a "classic comfort game" if you will. 😀
OpenRCT2 is an amazing re-implementation of this classic. The originals are still better than all the later versions of Roller Coaster Tycoon in my humble opinion.
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Reply 6063 of 7807, by TheWiredIsUponUs
Blasting it out with Duke Nukem 3D, baby.
Reply 6064 of 7807, by gerry
ncmark wrote on 2024-06-18, 23:44:
i've said this before i think, but i like blue shift a lot, especially in that the player is not the centre of the story, just trying to escape
StriderTR wrote on 2024-06-19, 08:29:
it does look good, should give this a try
Reply 6065 of 7807, by newtmonkey
It's been a long time since I got some good old DOS gaming done! A couple days ago I finally cleaned up the area around my dedicated DOS machine, and now that I'm not forced to see a disgusting sea of wires, I was finally in the mood to start the computer up and play some games.
Ripley's Believe It or Not! The Riddle of Master Lu
I've been reading old issues of CGW and PC Gamer lately, and the coverage of this game in these mags intrigued me. I knew of this game back in the day (I read both CGW and PC Gamer back then, of course!), but never ended up actually buying or playing it. I installed it tonight and gave it a try.
It's a traditional point and click adventure that runs in (only) SVGA, with a mix of digitized actors and rendered backgrounds. It actually still looks great today, imo, with detailed CG and fluidly animated characters. I've read that there's sort of a mandatory side quest throughout the game, where you need to be on the lookout for interesting items to add to your museum back home to keep it running, but I haven't played enough to really get into that.
Descent
I go back and forth between playing this in the Rebirth source port, and the original version on my DOS machine. Both are great ways to play this classic, but it just feels wrong to me to use a source port to play such an amazing game, when I have the original hardware to play it on sitting there. It just feels right playing it on a P133 with a decent joystick.
After reading about how the various difficulty levels play, I decided to just go with the default Rookie level. It seems like this was the intended difficulty level, with everything above it apparently being quite a leap in difficulty. I completed the first mission, and had a blast! What a cool game.
Reply 6066 of 7807, by ncmark
By the way, that half-life blue shift is on grossly overpowered system
Win98, AthlonXP 2400+, and radeon 9600
*laughing*
I believe someone on here once had a similar system and called it retro-rocket
Reply 6067 of 7807, by Ensign Nemo
newtmonkey wrote on 2024-06-19, 17:59:
I like to go on "period correct" gaming journeys using old books and magazines. I find it fun to start with a blank hard drive and install/play games in the order that they come up in old magazines. Same goes for the old books that came with a CD full of shareware games.
Reply 6068 of 7807, by appiah4
ncmark wrote on 2024-06-19, 20:04:
By the way, that half-life blue shift is on grossly overpowered system Win98, AthlonXP 2400+, and radeon 9600 *laughing* […]
*laughing*
Retro rocket is my C2D E6400 + X800XTPE running Win98SE. Heh heh..
Reply 6069 of 7807, by Joseph_Joestar
appiah4 wrote on 2024-06-20, 15:34:
Similar "max power" setup for me. It's great for running Win98 games at 1600x1200 with AA and AF cranked up.
Also, X800 series cards have the special temporal anti aliasing which ATi introduced way back. I've been experimenting with that as of late, and I really like it.
My retro builds
Reply 6070 of 7807, by gerry
Ensign Nemo wrote on 2024-06-19, 21:53:
this is probably the best way to simulate the actual process of back in the day, especially if you persist with a games even when it starts out frustrating or not so great. its too easy to just switch now and i tend to do that, sometimes its worth just slowing down and playing whats in front of you
Reply 6071 of 7807, by robertmo3
all that is left from this castle https://youtu.be/g2pse57Ab0E?t=2117
is this part of wall https://www.google.pl/maps/@54.3536985,18.659 … 05409&entry=ttu
it's funny i live in this city whole my life and if not this game i would never know about existence of this castle 😉
https://www.zamkipolskie.com/gdansk/gdansk.html
You forgot to say this game was to be like Indiana Jones, though I don't feel that atmosphere at all.
Reply 6072 of 7807, by newtmonkey
I do have a couple of the shareware collections on CD; I used to have a blast with these things back in the day, and it's still a ton of fun today to just randomly pick some game and play it for 15 minutes or so.
However, I've never thought of just opening up a magazine and installing/playing the games that are covered in order. This is such a cool idea! With a P133, you could just pick some random issue from 1996 or whatever and be able to run anything, and get a nice survey of games from that time in all genres. I will have to try that out sometime.
Reply 6073 of 7807, by Ensign Nemo
newtmonkey wrote on 2024-06-20, 18:04:
Computer Gaming World even allowed all of their back issues to be shared online when they went under:
https://www.cgwmuseum.org/index.php
Reply 6074 of 7807, by ncmark
Unreal 2!
Brough back some memories. The first computer I tried to run that on was a 1 GHz pentium 3 - woefully underpowered. Currently running on Athlon XP 2400 (and honestly even that seems slow)
Reply 6075 of 7807, by Joakim
Baldur's Gate 1 (enhanced edition). I am at the end, I never actually come this far. I mostly strolled around before and became a bit confused when I got Baldur's Gate.
I think I will skip the side missions and skip directly to bg2 and then perhaps dip into bg3 (if I have some way of playing it).
Reply 6076 of 7807, by Shponglefan
I do something similar with my various period correct builds. I like to load them up with games of the specific year(s) and see what it's like to play with the hardware of the time.
Going through old magazines and seeing which games were relevant at the time is fun too. 😀
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 6077 of 7807, by Shponglefan
Joseph_Joestar wrote on 2024-06-18, 16:41:
Playing through the original Doom games on UV is a good time, and feels closer to survival horror with the requirement to conserve ammo compared to just run 'n gun gameplay.
Especially with the some of the levels where there are a handful of enemies left that you can hear, but can't necessarily find.
Reply 6078 of 7807, by DosFreak
Playing Quake 2 Remaster.
Was massively put off by the brown and boring maps on original release back in the day so barely played much of it back then and it's still the same today but I'm pushing through. More color, more space missions, better maps please. (cough *duke3d* cough)
Playing on hard and only using special items only if feel like it which there is barely ever a need. Mostly rebreather and environmental suit (one map?) and rebreather not necessary most of the time if you move fast.
Finished Quake 2 campaign surprisingly quickly and am on the first expansion now.....I doubt my opinion will change much with this expansion. Mabye Quake 2 64 and Call of the Machine may be less meh. heh.
Something nice about playing old games is the top of my small case doesn't feel like the surface of the sun since the GPU is barely used so that's nice.
Make your games work offline
Reply 6079 of 7807, by Joseph_Joestar
Shponglefan wrote on 2024-06-23, 17:15:
Yup, I did have a few of those survival horror moments at the start of each episode, and especially during the first two levels of Ultimate Doom: Episode 4. Those maps are hard even on lower difficulty settings, and become quite a challenge on UV.
Despite "Thy Flesh Consumed" being my least favorite part of classic Doom, I actually had a decent enough time with it until I reached E4M6. Between the constant lava floor traversal, weird teleporter mechanics and the close quarters Cyberdemon fight, it just wasn't fun. The last couple of levels were mostly fine, featuring lots of enemies but with generally well designed environments. I think my biggest gripe with Episode 4 was its inconsistent difficulty and varying map quality. Still feels more like some fan made WAD than an official iD Software product.
My retro builds
