First post, by jnnelson79
Hi everyone!
My Toshiba Libretto 50 CT was working fine and even has a working battery (at least for about 30 minutes...) I left the system plugged in for a while to recharge the battery while it was off. The battery recharged like normal, and the charge light turned green. I've done this a few times with no issues. When I went to turn the computer on, it just stayed on a black screen. The lights came on for power, but that's it. Same behavior both on AC or battery.
So, I read some threads and saw that pressing F12 enables a BIOS Flash mode. So, I tried that. Luckily, the screen did come right back on and gave me the bios update message. So, I guess I need to flash / reflash the bios.
Where the update files I should use? I bought it from a seller on eBay with a CF card already installed and working. I read something about that needing a specific version, but it was already working fine with the CF card.
Also, I guess I need to buy a floppy drive to go with it. (I know I need the specific Libretto kind).
Also, I did take the laptop apart and checked the RTC battery. It looks fine. No corrosion or leaking at all that I can see, and it was placed nicely in a plastic sleeve to protect it as well. I tried starting the laptop without the RTC battery to see if that would help, and it didn't. F12 still works, but it won't boot.
Any ideas, or where should I get the BIOS Update to put on the disk? I did some searches but didn't find it.
