OS/2 install problems
First post, by Partaxx
Hey everyone,
I have this nice little 386SX 25MHz box with 4mb ram. I just went through the painstaking process of getting OS/2 2.0 installed on it, but as soon as it finished and rebooted, it immediately says "c0000005" in the upper left right after the OS/2 splash screen.
From what I can tell from research, this is a buffer overflow error - but I am not finding a lot on how to address this on an old machine like this. Is there some AUTOEXEC or CONFIG magic I need to work to get around this? Is there a problem since I had DOS installed previously? Do I just need more ram? Do I need to start from scratch? The machine meets requirements for the OS as far as I can tell. Not sure where to go from here!
Thank you for any ideas!!
Reply 1 of 7, by darry
You might be hitting this, especially if your VGA card uses a Western Digital chip.
Q. I'm getting a C000005 error during installation and can't continue.
A. The problem results from a conflict with some SVGA cards. There is a replacement BVHSVGA.DLL file available on the IBM NSC BBS (404-835-6600) that allows installation.
Source: https://www.os2world.com/wiki/index.php/OS/2_ … ons_and_Answers
Potential fix:
https://www.os2site.com/sw/drivers/video/misc/bvhsvga.zip
The attachment bvhsvga.zip is no longer available
Reply 2 of 7, by Grzyb
I recall 8 MB RAM quoted as the minimum - with 4 MB, it may run, but painfully slow.
Nie rzucim ziemi, skąd nasz root!
Reply 3 of 7, by Partaxx
Darry, you are awesome, I appreciate it! I will try this out and report back.
Reply 4 of 7, by Partaxx
Grzyb, good to know, thanks for the heads up - I think I will end up upgrading either way!
Reply 5 of 7, by Partaxx
Darry, that did it!!! Really appreciate the help man! 😁
Reply 6 of 7, by darry
Glad it worked.
I ran either OS/2 2.1 or 3.0 with 5MB of RAM on a 486 SX/25 for a while back in the day.
It swapped a fair amount, but it did work.
Oh, and random advice: do not leave a copy of a DOS executable named mouse.com (typically a mouse driver) in the root of your boot drive. On at least some releases of OS/2, that breaks mouse functionality as OS/2 tries to load that mouse.com instead of its own. AFAICR, this stemmed from c:\ being earlier in the path statement than the expected path. Pretty sure it was the default config, but maybe I was doing something wrong/unexpected.
Reply 7 of 7, by Partaxx
Lol, good to know! I was surprised that it actually found my old Microsoft Mouse so flawlessly. I feel like Windows is always a pain at first for that.
Honestly, I am pretty impressed with this little OS! Lots of cool things included!
