First post, by Ahrle
- Newbie
Pushed and pulled both sides of the bracket, moved the sink back and forth... it just won't release.
How would one remove it?
Thanks
Current main: Inspiron 8100, 512MB, GF2 Go, 1600x1200, dualboot 98/XP.
Thanks
You could remove the fan first, just to check if there's a mechanism under it.
Can you wiggle it a bit or is it really stuck? Maybe someone used adhesive instead of paste.
If the heatsink is moving, push the black retention clip down at one end, and careful lever it back with a flathead screwdriver.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Whatever you do, don’t tilt it. It might damage the processor die (core).
thandor.net - hardware
And the rest of us would be carousing the aisles, stuffing baloney.
PD2JK wrote on 2024-06-22, 18:37:You could remove the fan first, just to check if there's a mechanism under it.
Thank you. It's really loose and moves around easily, but the bracket won't release. I will try the screwdriver method.
Don't pry into the board. 😬
Dental floss between the heatsink and the processor is a better idea than prying with a screwdriver.
Is the hold down bracket still clipped over the socket lugs?
