Reply 20 of 25, by PC@LIVE
- Oldbie
berion wrote on 2024-06-22, 23:50:Ok I'll buy a 100 MHz Coppermine as the one I tried before was a 133 Mhz 866.
We'll see what happens. Thank you for all your help and support.
So, I'm pretty sure that if you find the right combination of HW, the card will work.
I think you are using the wrong components, and even if they work, they hardly work in that MB, you can do all the tests you want, but the result will always be the same, i.e. it doesn't start and no post code.
That is a Mendocino or Katmai CPU board (or how are they spelled?), you can try all the Coppermines you want, but they are electrically incompatible with the S.370, vice versa, if it was a Coppermine board, the Mendocinos also work, mine advise?
Buy at least one Celeron Mendocino, you should find them for cheap, if you're lucky, and find someone who has several, you can get some for the price of a pair (or could you even give them away?).
Then when the card is working, you can see if it works with Coppermine, if you skip this step, you will never know if it works, and all subsequent attempts could give the same result, moreover I think that by finding the right combination of working HW, you will be able start doing something with it, I imagine you'll want to play DOOM for example or simply load Windows 98 on it, and for that a Celeron 366 or 500, it doesn't make much difference, actually a 300A you can easily make it work at 450, and it would work more or less like a PII 450.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
