Reply 1780 of 3431, by sharangad
https://nirvtek.com/downloads/RReady.Alpha.20240621.001.zip
MD5: 387b8a6a6fd3b428eeba56c87977fadf
Dosbox is now integrated with RLauncher and can be launched and configured from within RLauncher. This is the recommended way of running Dosbox-Rendition. The store based version will always update dosbox-rendition and dosclient with the latest and greatest.
-Massive changed to Rendition register implementation. I hope this improves stability.
- Lots of other internal changes. Please check to see if whatever you play is stable.
- Rebel Moon chroma keying fix.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 1781 of 3431, by sharangad
Is Rebel Moon locking up for anyone?
I removed register locking and ICR2 works great, but Rebel Moon not so much. TR1 also seems to sometimes randomly slowdown.
Reply 1783 of 3431, by sharangad
Nascar 2 vastly improved. Similar improvements to Nascar 1999 (no vid yet).
https://youtu.be/EzpE-77F84Y
[edit] icr2 performance regression, will be fixed tomorrow.
Reply 1784 of 3431, by sndwv
Hi, I was wondering, as I never had or researched these cards: are there any games that only had 3d acceleration using one of these cards, or where 3d acceleration was superior to glide/3dfx?
Was checking out some of your videos. Results look impressive, but was wondering if there is much to gain over, say, openglide, dgvoodoo or 3dfx in dosbox staging for certain games, or if your wrapper is mostly for people with nostalgia towards rendition verite.
Reply 1785 of 3431, by sharangad
SODA Offroad
https://www.youtube.com/watch?v=0f38nzvFgPY
https://www.youtube.com/watch?v=uiyCT3FMcQA
and Indy Car Racing 2/Cart Racing 2
https://youtu.be/_XL2kaKnJhw
https://youtu.be/GPsD3yzrKw8
only had accelerated ports with Rendition.
Currently RReady (Alpha version only, not yet in the Microsoft store, but soon) is the only way to upscale Whiplash (https://youtu.be/oRMVeXXlgDM) to resolutions higher than 640x480. In the video, the geometry is being rendered at 4k/UHD. Eurofighter 2000+ is in the same boat (https://youtu.be/pZEoty04PpM), upscaling is not possible with 3dfx/Dosbox. EF2000+ still doesn't work properly with Dosbox-Rendition/RReady yet, having a lot of rendering defects and general instability. It's one of a number of apps still being worked on.
Scorched Planet might be another exclusive, not sure. It doesn't run with any form of Dosbox, even in software mode.
vQuake (does not run, yet)/vQuake2(works perfectly) are two version of Quakes which had native ports and looks like a software renderer with bilinear filtering. Some people prefer the look of vQuakes over regular Quakes, but it's just a matter of taste, I think.
Reply 1786 of 3431, by sndwv
Thanks! I like Indycar 2 and Fatal Racing, so I'll be checking these out. I think Mechwarrior 2 also looked quite different depending on the type of 3d graphics card?
Reply 1787 of 3431, by sharangad
sndwv wrote on 2024-06-23, 07:52:
It did yes.
Reply 1788 of 3431, by sharangad
With this release Nascar 2 and Nascar 1999 should work properly (100% with no rendering defects). Like with ICR2, you may need to set threadsafe=true in dosbox-rendition.conf, just like ICR2/Cart2. I hope to remove the need for this eventually.
https://nirvtek.com/downloads/RReady.Alpha.20 … .Nascar.001.zip
MD5: 617491421938bb13ff9bf389526b3ce3
Reply 1789 of 3431, by leileilol
sharangad wrote on 2024-06-23, 07:38:
not exclusive (Matrox MSI3D, and 3dfx (supposedly super rare))
Reply 1790 of 3431, by sharangad
leileilol wrote on 2024-06-23, 10:56:
Ah, my bad.
Reply 1792 of 3431, by robertmo3
every game can be checked here (including splanet 😉 ) https://gona.mactar.hu/3D/
Reply 1794 of 3431, by robertmo3
Reply 1797 of 3431, by sharangad
robertmo3 wrote on 2024-06-23, 11:27:
Thanks for that!
Reply 1798 of 3431, by sharangad
robertmo3 wrote on 2024-06-23, 11:34:
Scorched Planet doesn't run with any form of Dosbox, even in software mode.
i already told you it works in dosbox 😀
Re: RReady (Rendition Verite wrapper) Test Build (Alpha 1)
So it does, just takes a while to start up and no Rendition mode doesn't work at all yet.
Reply 1799 of 3431, by robertmo3
the list of games that cannot be forced to render in very high resolutions on voodoo wrappers is here marked with red X:
http://www.zeus-software.com/forum/viewtopic. … 72&p=3473#p3473
(excluding Battlecruiser 3000)
Starfighter 3000 might be excluded soon as the source was released recently Starfighter 3000 source
