DOSBox ECE (for Windows & Linux)
Reply 1540 of 1564, by xcomcmdr
Reading the github issue, it's understandable why it got removed.
Reply 1541 of 1564, by DosFreak
If discussion on this functionality for this other project needs to occur do it elsewhere (preferably not vogons), this thread is for DOSBox ECE.
Make your games work offline
Reply 1542 of 1564, by Ant_222
KainXVIII wrote on 2023-09-12, 12:45:
Yeah, i meant your pixel perfect shader in previous post 😋
Both your screenshots are truly pixel-perfect, with 2x2 square pixels and no apsect-ratio correction. The original resolutions are 640x400 for the first and 640x480 for the second screenshot. The first one has PAR of 1.2 (5:6) and should aspect-corrected if the output resolution permits, which in you case it does not. I am glad the pixel-perfect shader works at least in this situation, but the reliance on the GPU for so simple a thing as pixel-perfect scaling seriously raises the requirements for a DOSBox machine... I should like to see the pixel-perfect shader at work with a 320x200 program on a 1650x1050 display, where it should figure out to use 4:5 scaling, because 5:6 will not fit.
DosFreak, I bet your pardon for replying—didn't see your post.
Reply 1543 of 1564, by villeneuve
Thanks very much for ECE! I think it was the most widely used DOSBox variant in retro sim racing circles. I just read that it's development has come to an end, which is sad, but luckily there are alternatives. Question is though if Staging does everything that ECE did feature-wise.
Reply 1544 of 1564, by stanwebber
so i haven't quite given up getting ece working under win9x. awhile back i tried compiling with mingw and got a working ece build, but could never get fluidsynth working. well, i found a libfluidsynth v1.1.6 dll with glib dependencies stripped out and it works under win98se!
so if you take the last couple ece releases (r4482, r4481) and replace the sdl, sdl_net libraries with those from the vanilla dosbox v0.74-3 release plus the no-glib libfluidsynth.dll you get a working win9x dosbox ece.
however, there's something wrong with the built-in mt32emu library compiled in the last few releases of dosbox ece. for some reason it uses way too many cpu cycles. my 1.7ghz athlon cpu strains and barely keeps up. i used the ece r4481 source and compiled in my own v2.7.0 mt32emu library and the resulting build uses a third less (maybe even half the) cycles. i don't know what is going on.
i'm thinking i still have to compile my own dosbox ece. libfluidsynth will be impossible with anything less than visual studio 2008. maybe i can transplant the headers and libraries back into mingw afterwards or figure out how to do it all in vs2008 for win9x.
Reply 1545 of 1564, by stanwebber
morphinejh wrote on 2023-02-25, 14:44:
Well that's actually good news. And I have good news too. I got my Windows 98 box setup and ran into the same issues you did. I don't have an easy way to compile for Windows 98, but I know libglib has older binaries that do work on windows 98. I don't know the newest version that will work, but I know this version will work:
Hope it helps! More research coudl be done to find the absolute newest verison that would work. Or possibly a new build targeting Windows 98.
i tested all versions and glib v2.12-13 is the last release that will work under win98se.
https://download.gnome.org/binaries/win32/gli … lib-2.12.13.zip
https://gnuwin32.sourceforge.net/downlinks/li … onv-bin-zip.php
so if you replace the sdl, sdl_net libraries and the libglib, libgthread dlls plus add the renamed v1.9.2-1 iconv.dll you will also have a working dosbox ece under win9x. (same issue with mt32emu cpu usage still applies.)
i wonder if libfluidsynth v1.1.6 was still being used in r4482 or if it had been advanced past that long before. i'd much rather use a glib stripped fluidsynth, but v2 made quite a few advancements if it's been included in recent releases of dosbox ece. i believe the major motivation of fluidlite was getting rid of the complications of glib so good riddance...
Reply 1546 of 1564, by stanwebber
here is my complete compilation of dosbox ece for win98. everything is compiled in mingw except for libfluidsynth v1.1.6 where i used mingw-w64 and then transferred the headers and libraries back to mingw. i tested the build in win98se with athlon 1.7ghz and pentium3 850mhz systems and as far as i can tell all the patches are working. i expect my build will probably work with later versions of win95 as well, but i haven't tested. opengl did not work on the pentium3, but i expect this was because the video card drivers on that system didn't support higher than opengl v1.2. mt32emu (munt) uses about a third less cycles than the official dosbox ece build and you'll need a system north of 1ghz for smooth playback.
Reply 1547 of 1564, by 7F20
Is there anyway to display the video mode information in the status window? Staging and X both do this by default and it's immensely helpful in debugging and setting video modes. Or if not in real time, then can I have all that resolution switching/setting info saved in a debug file or something?
Thanks
Reply 1548 of 1564, by villeneuve
@stanwebber: Great work and thanks very much for also sharing the result! What's the performance like on the two systems you mentioned as your test beds. Does a trusty old P3 850 manage to run mid-90s SVGA DOS games or only older ones (up to which point roughly) and how does the Athlon 1.7 manage those? Btw I lately ran DOSBox Staging on a current Linux OS running on an old 2.3 GHz C2D with onboard Intel GMA4500 graphics and at least on that platform DOSBox OpenGL was so slow that you needed to disable it anyway.
General question: Normal DOSBox ECE will run on Windows XP, doesn't it?
@7F20: Having dealt with that Linux C2D system mentioned a few lines above this one I can tell you that a lot is/can already be logged into a DOSBox log-file. At least on DOSBox Staging that's the case but I'd expect other DOSBoxes to do the same.
Reply 1549 of 1564, by stanwebber
villeneuve wrote on 2023-12-12, 13:56:
the athlon 1.7ghz system has a radeon 9800 pro so it can handle pretty much anything into the xp era (plus i can run it at 5-2-2 ram timings). either my or sergm's win9x compilation of munt + dosbox pegs the cpu at about 66% (official ece 100%).
the p3 850mhz system has a rage mobility m1 so it does ok running mid 90's svga games with fluidsynth enabled so long as it is a modest sized soundfont. munt is a no-go which is disappointing as i think 800mhz was given as the min requirement (maybe for the xp & later build).
i also run dosbox-x on a mid-era c2d laptop, but it has an upgraded nvidia videocard so it runs fine (although ubuntu dropped the proprietary nvidia drivers covering my card from the latest kernels so i have to go third party)
normal dosbox ece runs on xp without any modification.
Reply 1550 of 1564, by villeneuve
Thanks for your answers! I didn't imagine that Munt would be the most taxing part, I thought SVGA graphics would already stress such old CPUs too much.
Reply 1551 of 1564, by DrNilsson
Sorry if this is necro posting but DosBox SVN is in r4483 and i was wondering if anyone could do me a favor and compile a r4483 version of ECE. I know there's dosbox Staging and dosbox-x available but i just love the advanced but simple (in a good way) funktions and settings in ECE. 😀
Reply 1552 of 1564, by villeneuve
IMO Staging is as easy as ECE and has even more important features.
Reply 1553 of 1564, by DrNilsson
villeneuve wrote on 2024-07-01, 22:34:
Yeah, true but the amount of settings in staging was very overwhelming. But i guess it's time to learn them. But still, if anyone in the future would like to compile ece with latest dosbox svn then they would have my gratitude. 😀
Reply 1555 of 1564, by ripsaw8080
Rank DOSBox Author
DOSBox Author
DrNilsson wrote on 2024-07-01, 18:44:
FYI, r4483 is a compilation fix for an older version of Visual Studio, so you would not get anything functionally different compared to the r4482 binaries.
Reply 1556 of 1564, by DrNilsson
7F20 wrote on 2024-07-02, 14:38:
ECE is over indefinitely. See the EOL notice on the homepage: https://yesterplay.net/dosboxece/
I know, it was my favorite version of dosbox for a while. Hard to let go. 😜
ripsaw8080 wrote on 2024-07-02, 17:09:
I did not know that, thanks 😀
Reply 1557 of 1564, by igermi
guys sorry for an old post- but does anyone know where to download the last version of dosbox ECE? Is there somewhere else rather than the yesterplay site? The yesterplay site has a 404 at the bottom where the downloads should be.
Reply 1558 of 1564, by villeneuve
I don't have a link, but if DOSBox ECE r4482 was the last version I could e-mail it to you. PM me with your address if you want that.
Reply 1559 of 1564, by torpedo
igermi wrote on 2024-09-17, 02:46:
Windows version is on archive
https://web.archive.org/web/20240514031157mp_ … 0ECE%20r4482.7z
