386 board problem
Reply 20 of 22, by Anonymous Coward
Are you sure the 80mhz crystal was firmly seated. It’s the heartbeat of the system, so if not seated correctly the system will appear dead. Also don’t reverse orientation.
Reply 21 of 22, by majestyk
Have a closer look and "386WB 33MHz" will appear:
The attachment IMG_3652a.JPG is no longer available
Reply 22 of 22, by naujoks
Magic! 😀
