5.25 floppy disc not formatting
Reply 20 of 84, by Deunan
Usually IMD will reformat the track (this alone might be helpful) before writing it but the first sector is always the one after index pulse. Interleave won't change that and I'm also not sure what can be done with the advanced options either.
The problem with floppies, if there really is surface damage on track 0, is that every sector there is used for something and must be good. Unlike on HDDs were the partition table starts at least one track above first sector, so that all other sectors on the first track are in fact unused - and could be for example made to spoof a damaged first sector if only there was an easy way to change the formatted sector IDs by hand. But this is very OT.
Reply 21 of 84, by wbahnassi
Easy with IMGDisk. Use the Erase Disk functionality. Do it a couple of time then go back to DOS and do FORMAT A: /U /F:1.2
If the disk has any life in it, this will make it work. If it's damaged (check the media if it has discoloration or stripes), then it's game over.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 22 of 84, by butjer1010
keenmaster486 said what i think is reason. Probably You didn't set right type of FDD in BIOS!
Reply 23 of 84, by jude1977
wbahnassi wrote on 2024-07-02, 19:41:
Hi how do I go about using the erase disk functionality what is imgdisk I haven’t heard of this before
Reply 24 of 84, by Deunan
It's a program called ImageDisk, or IMD in short. While it can do some nice things it's a rather advanced program for creating sector-based floppy images. Frankly I think you'd find it rather frustrating to use, what with all the options that need to be set in it before it can be even used properly. Feel free to try but if you are going to hunt down more software then I think trying FDFORMAT first would be way easier.
Reply 25 of 84, by wbahnassi
Download ImageDisk from here:
http://dunfield.classiccmp.org/img/
Now the steps are from my muscle memory, so I might forget something:
  1. Run IMD.COM
  2. Dismiss the intro help text (press ESC)
  3. Press space to modify options
  4. Make sure Cylinders are 80 (1.2MB disks)
  5. Set Sides to Two
  6. Set Double-Step to False
  7. Press ESC to leave the options
  8. Navigate to Erase Disk and press Enter
  9. Insert your disk in drive A and start the process
Erasing is going to blindly write a full-track single-sector on each cylinder. This will erase metadata in-between the standard IBM format sectors and the disk will basically become in "Unformatted" state.
I personally use this to revive disks which got "soft-damaged". I repeat the erase a few times. Once done, go back to DOS and try formatting again, and force the format using the /F parameter. Hopefully your Track 0 error will go.
Reply 26 of 84, by jude1977
wbahnassi wrote on 2024-07-03, 09:03:
Download ImageDisk from here: http://dunfield.classiccmp.org/img/ […]
  1. Run IMD.COM
  5. Set Sides to Two
Hi I downloaded the program I’ve tried following your instructions but when I press space bar it just makes a noise
I’m not Shure how to get to format disc option I have tried a few options and I just get a error message ive sent a picture of the error message I get
Reply 27 of 84, by kotel
Check if you set correct BIOS settings and can still read good know floppies.
I couldn't save them, but that doesn't mean I can't save myself!
Ready yourself!
Reply 28 of 84, by jude1977
kotel wrote on 2024-07-04, 12:56:
Hi in my bios I have 5.25 floppy assignd to a and my 3,14 disc drive assigned to b my 5.25
Floppy disc drive reads disks ok but won’t format blank disks
Reply 29 of 84, by wbahnassi
jude1977 wrote on 2024-07-04, 06:54:
Heh? Seems to me you didn't even get into ImageDisk at all. The program has a red/blue screen similar to this:
You get into this by running IMD.COM. Once there, the rest of my steps should apply.
Reply 30 of 84, by jude1977
wbahnassi wrote on 2024-07-05, 10:50:
Heh? Seems to me you didn't even get into ImageDisk at all. The program has a red/blue screen similar to this: https://d4.altern […]
Hi I actually got that screen when I started the program but when I followed your steps and tried pressing space bar it just makes a beeping noise and I can’t seem to change the settings and I’m not Shure what part of the program I use to format
The floppy disc
Reply 31 of 84, by jude1977
jude1977 wrote on 2024-07-05, 11:17:
The floppy disc also I’m running the image disc program from a 3 and a quarter disc is that ok
Reply 32 of 84, by jude1977
Hi I don’t suppose you would have a link to a video of how to use the program as I’ve looked on YouTube and can’t seem to find any
Reply 33 of 84, by wbahnassi
What was your search query on YT?
Reply 34 of 84, by jude1977
wbahnassi wrote on 2024-07-05, 12:04:
Hi the search query was how to use the disk image program or image disk program video tutorial if there is one
Reply 35 of 84, by keenmaster486
jude1977 wrote on 2024-07-05, 10:01:
The first drive on the cable (the one connected to the end) is always the A drive. The second (the one connected in the middle) is always the B drive. You cannot assign drive letters in the BIOS. All you can do is tell the BIOS which drive is connected to which connector on the cable. Check which drive is connected where, and update the BIOS to reflect that.
World's foremost 486 enjoyer.
Reply 36 of 84, by butjer1010
keenmaster486 wrote on 2024-07-05, 19:44:
And also there is probably more than one option in BIOS on 5.25 FDD in size. Be sure You did check the right size!
Reply 37 of 84, by jude1977
butjer1010 wrote on 2024-07-06, 09:43:
Hi I’ve checked both my drives and how they’re connected and the settings in bios are correct according to how the drives are connected as far as I know and the 5.25 fdd size is set to 1.2 my floppy disk drive is a 1.2 size
Reply 38 of 84, by butjer1010
[/quote]
[/quote]
Do You know the model of this FDD? You checked it is 1.2MB? Sorry if i'm boring, but this was my problem once (unable to format, read ok), when i didn't set right option in BIOS. 😀
Reply 39 of 84, by jude1977
butjer1010 wrote on 2024-07-06, 16:02:
[/quote]
[/quote]
Hi your not being boring I’m grateful for any help on this topic the brand of fdd is Tandon and the seller I brought it of on eBay
Says it’s a 1.2 model I’ve set it on 1.2 in bios but yes the brand of fdd is definitely Tandon he says
