Reply 20 of 117, by swaaye
From event viewer:
Event Type: ErrorEvent Source: Application ErrorEvent Category: NoneEvent ID: 1000Date: 2/15/2008Time: 2:44:21 PMUser: N/AComputer: SWAAYEDescription:Faulting application dosbox.exe, version 0.72.0.0, faulting module dosbox.exe, version 0.72.0.0, fault address 0x00095800.For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.Data:0000: 41 70 70 6c 69 63 61 74 Applicat0008: 69 6f 6e 20 46 61 69 6c ion Fail0010: 75 72 65 20 20 64 6f 73 ure dos0018: 62 6f 78 2e 65 78 65 20 box.exe0020: 30 2e 37 32 2e 30 2e 30 0.72.0.00028: 20 69 6e 20 64 6f 73 62 in dosb0030: 6f 78 2e 65 78 65 20 30 ox.exe 00038: 2e 37 32 2e 30 2e 30 20 .72.0.00040: 61 74 20 6f 66 66 73 65 at offse0048: 74 20 30 30 30 39 35 38 t 0009580050: 30 30 0d 0a 00..
And a second crash for you
Event Type: ErrorEvent Source: Application ErrorEvent Category: NoneEvent ID: 1000Date: 2/15/2008Time: 2:53:55 PMUser: N/AComputer: SWAAYEDescription:Faulting application dosbox.exe, version 0.72.0.0, faulting module dosbox.exe, version 0.72.0.0, fault address 0x00095b66.For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.Data:0000: 41 70 70 6c 69 63 61 74 Applicat0008: 69 6f 6e 20 46 61 69 6c ion Fail0010: 75 72 65 20 20 64 6f 73 ure dos0018: 62 6f 78 2e 65 78 65 20 box.exe0020: 30 2e 37 32 2e 30 2e 30 0.72.0.00028: 20 69 6e 20 64 6f 73 62 in dosb0030: 6f 78 2e 65 78 65 20 30 ox.exe 00038: 2e 37 32 2e 30 2e 30 20 .72.0.00040: 61 74 20 6f 66 66 73 65 at offse0048: 74 20 30 30 30 39 35 62 t 00095b0050: 36 36 0d 0a 66..
I'm not sure it's at all related, but I notice that the game sort of stutters maybe with sounds playing back. And it feels like eventually one of these stutters crashes it....
And the oddness of how it won't even successfully load a mission in SVGA at all with a full install to the HDD (no cd access at all)... Almost seems like some sort of IO issue.
