First post, by psaez
Hi
I see in every 98se recommendations post that I must install that driver.
When I try to install it, I can ser a dialog were it tells that its for english version only. I installed it but after that some of my OS parts changed to english, for example start menu.
Does exist this driver but for spanish windows 98?
How necessary is to have it?
Reply 1 of 5, by Yoghoo
psaez wrote on 2024-07-08, 11:20:
You only need it if you want to use USB flash drives in Windows 98SE. If not then it's not needed. There are localized versions for older versions I believe but I don't know if there are any for Spanish and where they are located.
Reply 2 of 5, by mmx_91
Hi, I have faced same problem several times, as NUSB also changes some labels and menus of the OS (Inicio switches to Start menu and it feels weird).
I use the one called nusb33es.exe you can find it in Google, or if you cannot find it (it's a bit tricky), I can send it to you when I arrive home in the evening.
Ya me dirás 😉
Reply 3 of 5, by theelf
Siempre en ingles windows 9x, en español es una molestia, better in english win9x, localized dll, updates, etc not always exist, most of mods, dll hex edits, etc are for english too
Anyways, here you have the spanish usb
Reply 4 of 5, by psaez
Yoghoo wrote on 2024-07-08, 11:49:
you mean that 98SE was not compatible with usb pendrives? are you sure? I remember they working I think
mmx_91 wrote on 2024-07-08, 12:22:
Ya me dirás 😉
theelf wrote on 2024-07-08, 12:30:
Hi guys, españoles también? well, I'm making this retro build in spanish because I wanna have it exactly how I had in my childhood.
Ouch, that nusb33es.exe has a lot of virus alerts, and the english version nusb33e.exe has only one, so probably that file is infected 🙁
Saludos compañeros
Reply 5 of 5, by Gmlb256
psaez wrote on 2024-07-08, 12:59:
Unlike later versions, Windows 98 SE and below didn't come with a generic USB mass storage driver.
