First post, by jateu01
Hi all have a mare with a dos pc that I'm trying to connect to a windows xp 2000 network. There is no way around the configuration of network as the device attached to system has to run on dos. I am struggling to understand what I need to do to get dos to talk to network. Os there anyone out there I can chat to to understand what's going on.
Thank you
Reply 1 of 2, by wierd_w
Your DOS pc will need the following:
Supported NIC
DOS Packet driver
Microsoft Network Suppliment Diskette set for DOS
the network suppliment for dos has dos NDIS packet drivers baked in, but does not know about all possible cards. It has the option to load an unlisted driver during installation. If you need one for your card, you will have to hunt for it.
this is the basic process:
http://www.kompx.com/en/network-setup-in-dos- … work-client.htm
The ultimate goal, is to get the dos system configured to either grab an IP Address from DHCP, or have one manually assigned in your subnet, then use the NET command to mount file shares or printers.
Bear in mind, that the packet driver, and the protocol stack, consume A LOT of memory.
Reply 2 of 2, by myne
Try find one of the old ultimate dos network boot disks.
See if it works.
If it does, copy the relevant bits over
I built:
