First post, by Inrit
Hi there,
I have a 486 that was working well for years, until recently the 3.5" floppy stopped working, and then the HDD stopped working (now won't boot). The AMIBIOS configuration cannot detect the HDD values either, whereas it previously could.
The machine has a real 5.25" floppy and 3.5" floppy, and a CF card to IDE adapter with a 512mb card for HDD.
I have tried:
- Replacing the controller card
- Replacing the CF card adapter
- Touching up all the solder joints on the original controller card, cleaning its contacts, and trying it again
- Moving the new controller card to a different ISA slot
- Booting off a DOS 3.5" boot floppy
None of these helped until I moved the controller card to a new slot. When I did that, the BIOS configuration once again was able to auto detect the HDD values and after saving those, the machine started to boot into Windows 95. However, partway through startup it failed with a blue screen of death saying the C: drive was not writable. When I rebooted, the BIOS configuration could again not detect the HDD.
So that's when I decided to try booting off a 3.5" floppy (the drive light went on after each boot). But that failed, saying the disk was not bootable (I know it is).
What could be causing this set of problems? It all seems related to the controller card, but I've now completely replaced that, as well as the CF card adapter. Not sure where to go next, since that already seemed like the nuclear option!
Would love any ideas.
Thanks!
