Reply 140 of 177, by RichB93
Right, I should be able to help out with this shortly. I have a number of devices I can offer, but I imagine most of them have already been covered.
- SC-55mkII
- SC-88ST
- SC-88ST Pro
- SC-8850
- MT-120
- PMA-5
An SC-33 is also arriving next week.
One thing I must say is that although the demo tracks are indeed very well programmed, they don't fully exploit the differences that can be heard between different engines employed in the devices. For example, a rendition of Michael Jackson's Thriller (which sadly doesn't have any author information embedded) employs some clever filtering on both the brass sections (to make them brighter and snappier) and on the synth sections (to make them sound more analog) and this sounds vastly different across modules.
That being said, having re-read the first post, this project mainly focuses on the DAC rather than the actual device engine quirks and features.
Just a little feedback anyhow - I'll try and get these recordings done at some point soon for you.
And for anyone who is curious about the track I mentioned - please see attached. I've edited the track to remove the vocal tracks as they always sound terrible, no matter what song.
Reply 141 of 177, by esher
As a fact, i can confirm, that the MT-32 analog recordings looks almost (99,99%) the same as digital recordings from my MT-32 SPDIF mod.
They are not bit-to-bit identical, but this is also about different analog line in level, which i cannot set to equal digital in.
P133/Marl/32Mb/CT2930/PicoGUS 2.1/MT-32/SC88 Pro/MU-128
Reply 142 of 177, by Kahenraz
firage wrote on 2022-03-12, 12:43:
Sounds very interesting. I'd be happy to participate with my SCC-1 sound card in any way that's helpful. 😀
Recording gear and methods will impact the audio samples, so it'll be good to attach some of that information to all the recordings.
I did not read through this whole thread, so I apologize if this was already mentioned, but there are two versions of the SCC-1; the SCC-1A and SCC-1B, which the specs look a lot like the earlier SC-55 (not fully GM compatible) and SC-55mkII.
There are also different firmware versions for otherwise identical synthesizers, which could produce a different output. So for any submissions, the firmware version should be included as well.
See here for some research I did on all of this previously:
Significant differences with certain MIDI files across Roland synthesizers
Reply 143 of 177, by firage
Kahenraz wrote on 2024-08-21, 18:27:
I did not read through this whole thread, so I apologize if this was already mentioned, but there are two versions of the SCC-1; […]
Sure, there are ROM versions for all of this stuff. Minor firmware changes don't usually make a difference unless the material is specifically picked to bring it out, though it's always interesting when you do find something.
I know a major revision exists that's marked "SCC-1A "on the PCB. (I believe "SCC-1B" is just an SKU for the SCC-1A.) Mine is an original SCC-1 without the A. From my testing: "Equivalent to SC-55 version 1.2x plus an intelligent mode MPU. Features Capital Tone Fallback and drum channel program changes also fall back to nearest like early SC-55's. GM standard configuration of PC#122 Breath Noise / Fl. Key Click, but doesn't have the additional instruments from SC-55mkII." I can tell you that the top of the Program ROM chip reads "GSS.PRM.A 2, R15279809".
My big-red-switch 486
Reply 144 of 177, by Kahenraz
I read that it's not fully GM compatible, because it interprets the GM reset command as GS reset, like the other early SC-55s, can you confirm? I think that this is a problem for all firmware prior to 2.xx.
Reply 145 of 177, by firage
Kahenraz wrote on 2024-08-22, 12:14:
I'll have to re-check whether it flips Rx.NRPN on GM reset, but I'm quite sure it's just a GS reset. Because that's how the SC-55 originally worked, games do use GS features despite sending GM resets. Strict GM devices are more trouble then.
Reply 146 of 177, by Kahenraz
What does that mean? More trouble for newer devices?
Reply 147 of 177, by firage
I mean depending on your synth's reset behavior one game will sound as designed and another will not. The original SC-55 behavior was de facto standard for a couple of years.
Reply 148 of 177, by RetroGamer4Ever
On a seemingly random notion, I just installed the last version of Quicktime For Windows on my computer and the MIDI (Roland GS soundset) works wonderfully. It kicks the crap out of the Microsoft Synth and it's DLS file. It doesn't match up to the SoundCanvas VA, but it's pretty passable with GM and basic GS files, so maybe it should be added to the comparison list.
Reply 149 of 177, by Marco
Nice comment. Didn’t know nor remember that QuickTime would install midi drivers. Thx.
1) VLSI SCAMP 311 | 386SX25@TI486SXLC2-50@63 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | WDC160GB/7200/8MB | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | LAPC-I
Reply 151 of 177, by Spikey
Yeah, basically hundreds of Roland keyboards used either direct Sound Canvas sample sets, or supersets of them - some new ones still have the SC-8820/50 set but expanded. There is probably 200+ keyboards that would meet the criteria, but nearly no-one in this space will have them.
I think all the Roland EM boards were Sound Canvases. The EM-20 is some version of a SC-55 I think, possibly.. After checking, it's in fact a hybrid of the SC-55, 88, 88Pro and even MC-303 totalling an 8MB sample set (versus 2MB for the usual SC-50 or '55 minus MT-32 tones').. weird. I think something similar would be used in some of the MT "Sound Canvas speaker" units, for reference.. Making a note of that. I think one of them has the same sound set.. MT-90U or similar.
The AT-90 appears to be a SC-50 GS part married to a different sound set of unknown origin, at least to me. Interesting.
Reply 152 of 177, by RetroGamer4Ever
Roland still uses a basic GS offering on it's home/studio pianos, for the purposes of MIDI file accompaniment and composition, but I'm pretty sure that it's been gone from their production and performance keyboard line for many years now, probably since the early 2000's. Yamaha also still has their basic XG implementation on some of their equivalent products, which also includes the emulation of basic GS that XG offered through the TG-300 and others.
Reply 153 of 177, by Spikey
RetroGamer4Ever wrote on 2025-01-27, 19:22:
Looks like Roland's E-A7 current Arranger keyboard still uses almost all of the SC-8820/50 instruments in its patch map, for reference - some GM patches derived from the SC-55 I would imagine.
GS specifically isn't offered, seemingly replaced by GM2, which is mostly GS instruments being included in the official standard anyway. Although I think all the instruments are there, just not mapped to GS in that sense.
Looks like the Roland BK-5 arranger keyboard is also heavily using SC-8820/50 tones, and IS explicitly GS compatible still.
Reply 154 of 177, by RetroGamer4Ever
Actually, I just discovered that both of the products you mentioned are full GS synths, though they are not advertised as such in the specs or use the GS branding anywhere on the body. The MIDI implementation document for both says that the default operating mode for both products is GS, with GM1 and GM2 as optional operating modes.
Reply 155 of 177, by Spikey
Well, we both learned something today!
As far as bringing it full circle, I'm not interested in including every random GS keyboard, and it's not really what old gamers care about in any case. Some exceptions for keys like the JV-50 (literally a SC-50 keys with JV expandability, but possibly with some SC-88 tech as well), SK-50 (SC-50 keys but with 55 output stage/DAC), and so on.
If people submit recordings of some, it's fine to include it, but the goal is not to include every one by any means. Most pre-2000's ones are equivalents of hardware modules, the variations being of more interest like the examples mentioned above, and post-2000 are random arranger keyboards with modern for the era tech that no longer relate to the SC core set, and that most people wouldn't be interested in, or would have trouble, acquiring.
While newer products like the SD-50, etc also fit that bill, they're modules/desktop units and not huge keyboards.
Reply 156 of 177, by Gradius2
Sorry for bump.
I modded my SC88 to fully digital output from over 10 years ago, if you don't like the DAC (you shouldn't), and want the REAL sound coming from it, just modded it already.
Reply 157 of 177, by Spikey
Bump is fine, but the device is analog and has a great, pro DAC - the BurrBrown PCM69. Roland used this DAC in many products that are very well-regarded for their sound quality. At worst, it would be established as a high-quality but not exceptional DAC.
Chances are the analog output would compare favourably to the digital output.
Please:
1. Share the process you used to mod your SC-88.
2. Provide recordings of your SC-88 per this thread's guidelines - 24-bit, 96kHz, 10 seconds of silence before music plays (IIRC that's what was agreed on?) - to showcase its ability. Respectfully, while your opinion is valid, it is not scientific or useful in isolation.
3. Please advise us to the resolution/bitrate the digital output is locked to. 44.1, 48 or other kHz and how many bits? Bitrates such as 16-bit and resolutions such as 44.1kHz may introduce additional errors and therefore be undesirable.
Reply 158 of 177, by stgiga
I have an SC-D70
I'm Nonbinary and neurodivergent.
I use they/them. It can also be written as ᵺ㏟.
Reply 159 of 177, by RetroGamer4Ever
We need to figure out the technical process for switching an SD-50 to digital output. It is the only module that Roland still supports on current systems, they are readily available for use, and the quality is definitely there, from the game MIDI vids I've viewed on YT.
