Windows 98 SE gets stuck at PNP Detection
First post, by itzCrassio
Hello,
I was trying to install Windows 98 Second Edition on this PC:
-AMD Athlon 64 3000+
-1GB RAM
-NVIDIA Geforce2 MX200/400
-200 GB HDD (SATA controller set to IDE mode)
The first part of setup went smoothly, then when it restarted, and went to the plug and play devices, one of these would happen:
-Only the window would freeze, mouse and keyboard still working
-The entire system freezes
I already tried the following things:
-setup /p i
-Restarting PC
-Disabling ACPI
It boots in safe mode, but I want it to work normally, but it can't if it can't finish the PNP detection.
Please help.
Reply 1 of 22, by wbahnassi
Try reducing memory first... then a different IDE device (like a real IDE HDD).
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
Reply 2 of 22, by Repo Man11
The RAM limit for Win98 is 512 megabytes and the hard drive size limit is 128 gigabytes - try reducing the amount of RAM and use Seatools or something similar to reduce the effective size of the hard drive.
Reply 3 of 22, by itzCrassio
Repo Man11 wrote on 2024-07-18, 17:57:
Can I just do it by editing the system.ini file? The hard drive I could do though.
wbahnassi wrote on 2024-07-18, 17:55:
I don't have any IDE HDD, I only have SATA.
Reply 4 of 22, by wbahnassi
You can use Win9x memory burn (BURNMEM.SYS) to reduce memory (find it online). But you must be sure it remains in your config.sys during Win98's install. The installer might remove it, and it's best to intercept the first restart and boot to a boot disk then edit C:\CONFIG.SYS and ensure memory burn is still the first line, then restart and allow the installer to continue as usual.
For HDD, as mentioned, SeaTools should help limit the size.
Reply 5 of 22, by itzCrassio
wbahnassi wrote on 2024-07-18, 18:51:
Which SeaTools version should I use and can I just use the command prompt mode of Windows 98 to edit the config.sys file?
Reply 6 of 22, by Repo Man11
Phil demonstrates some methods for setting up a hard drive to work with Win98 here:
https://www.youtube.com/watch?v=cCulATQ7GlM
Reply 8 of 22, by itzCrassio
I also tried HIMEMX, BURNMEM, patcher9x, unplugging everything, setup /p g=3, deleting enum regedit key in safe mode and restarting, underclocking CPU to 800 MHZ, using cpuspd utility to slow down the cpu and also setting the hdd's size to 32 gb with seatools. It dosen't work at all. IT'S STILL STUCK.
Reply 9 of 22, by itzCrassio
Edit: Just noticed that the network, ide and sound card had the same IRQ, can this potentionally be the problem?
Reply 10 of 22, by PD2JK
Yes.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 11 of 22, by VivienM
What chipset are you running?
I was trying to install Win98 SE on a K8M800 with a VT8237 I think it is... and... well, Win98SE does not like the SATA at all. I think it has something to do with the memory addresses being different than what it expects for a traditional primary/secondary PATA controller. Some Intel boards of a similar vintage had a feature to remap the SATA controller to the traditional PATA memory location to facilitate Win98 installation, but my board, at least, doesn't have that, not sure if the VIA chipsets have that ability.
Eventually bit the bullet, got a Startech IDE to SATA adapter for my SSD and a NOS PATA ODD, and then Win98 SE installed fine.
Reply 12 of 22, by itzCrassio
VivienM wrote on 2024-07-19, 23:52:
VIA K8T800 chipset
Reply 13 of 22, by kheper
itzCrassio wrote on 2024-07-19, 18:49:
Try any or all of the following -
In the BIOS, look in the "PnP/PCI Configuration". Does it read "PnP OS Installed" = "YES"?
Move the sound card to a different PCI slot. (Or, remove it for now.)
Plug the drive into the second SATA controller. Force it to boot off of the second controller. In the BIOS, look in "Advanced BIOS Features". Set the "First Boot Device" to "HDD-1" or similar.
If none of the above fixes it - as a last resort, you can manually configure IRQs in "PnP/PCI Configuration" with "Resources Controlled By" = "Manual".
Reply 14 of 22, by itzCrassio
kheper wrote on 2024-07-20, 11:22:
Try any or all of the following - […]
i could try but i was hoping that i dont need to open up the pc
Reply 15 of 22, by itzCrassio
Maybe it's a bad idea to boot from an external USB drive with DOS, cause it just puts the boot files on the USB.
Reply 16 of 22, by kheper
itzCrassio wrote on 2024-07-20, 12:48:
I'd try checking the BIOS first - for "PnP OS Installed". No need to open the computer.
In the BIOS, look in the "PnP/PCI Configuration". Set it to "PnP OS Installed" = "YES".
Reply 17 of 22, by itzCrassio
kheper wrote on 2024-07-20, 12:57:
I'll try it.
Reply 18 of 22, by VivienM
itzCrassio wrote on 2024-07-20, 09:57:
VIA K8T800 chipset
Then... hopefully you have more luck than me, but I got exactly nowhere trying to do SATA with Win98 on that family of chipset. Had same issues you did. Once I removed the SATA drives and turned off the SATA controller in the BIOS (even having a SATA ODD plugged in was enough to make it sad), it was happy...
Reply 19 of 22, by itzCrassio
VivienM wrote on 2024-07-20, 13:22:
VIA K8T800 chipset
The onboard SATA feature which allows you to choose between IDE and RAID?
