First post, by TheWiredIsUponUs
I'm not sure what the best patch engines/creators are for MS-DOS. My goal is to find one that can do byte-to-byte patchers, and that it can be compiled as an executable once created.
Any help would be appreciated. Cheers.
Reply 1 of 3, by gerwin
I only know this one for DOS:
http://www.shdon.com/software/patches
https://web.archive.org/web/20120119073819if_ … les/patcher.zip
https://web.archive.org/web/20120119073829/ht … patcher.src.zip
Reply 2 of 3, by TheWiredIsUponUs
gerwin wrote on 2024-07-18, 00:49:
I only know this one for DOS: […]
Cheers, friend. I'll check this out and will let you know what I think.
Reply 3 of 3, by TheWiredIsUponUs
TheWiredIsUponUs wrote on 2024-07-20, 18:32:
I've tested it in DOSBox-X, but it says that the executable is not a DOS program. I meant in the title as an 'MS-DOS patcher' and clearly not a Windows command-based program.
