Reply 80 of 230, by ElectroSoldier
- Oldbie
Hoping wrote on 2024-06-22, 20:45:On the other hand, I already received the Quadro K620 and has exceeded my expectations at the moment with 20539 points in 3DMark […]
On the other hand, I already received the Quadro K620 and has exceeded my expectations at the moment with 20539 points in 3DMark 2006 and a minimum of 70 fps and a maximum of 232 fps in FEAR with a resolution of 1280x1024 and the entire configuration to the maximum, AA X4, Aniso X16.
I still want to try more things with the drivers since I used a driver that I found on the Internet that did not even had the HDMI audio driver.
Temperatures are quite good at the moment with a maximum of 67 degrees celsius with the case closed.
Thank you very much to @Ozzunej for the suggestion of the K620.
Edit: I paid 30€ shiping included for the K620, by far, more reasonable than the prices of the 750.
I downloaded 3DMark 06 as I was curious how the Quadro K620 measures up to the 750Ti.
On an i7-3770, 3.47Gb RAM, 1Tb SSHD and a 750Ti it scored 26010 3DMarks. SM2.0 Score: 10210 HDR/SM3.0 Score 12268.
Desktop screen resolution was set to 1280x1024 but I dont know what it tests at.
The numbers are higher as expected but I know nothing about benchmarks so what does that mean in practical terms?
I paid £35 delivered for my 750Ti.
