First post, by AgustinCordes
Hi all!
I need assistance to confirm if an original IBM CGA card is supposed to work in a 286 clone motherboard. This is a VLSI in good shape that boots fine with those common Winbond cards and an ATI Wonder XL24. However, when I plug in the CGA, nothing happens -- not one beep.
The attachment cga.jpg is no longer available
I'm pairing this with an IBM 5153, and when the computer turns on, the monitor does get some signal (goes from white shade to black), but nothing else. I tried closing the JP7 jumper which, according to the manual, toggles between mono and color monitor. BIOS is set to COL 40.
The attachment jump.jpg is no longer available
Upon first sight, the CGA card is in solid shape. The 5153 seems to be in working condition too, but the XL24 may be too much for it, or maybe I need to configure it with VINSTALL. See the video -- the horizontal refresh is wrecked, but I suspect it's a combination between the monitor and the card. For now, I'd like to get that CGA working since it's the perfect match for the 5153. Is it possible it was only meant to work with original IBM hardware?
IBM 5153
Many thanks in advance!
Reply 1 of 17, by Horun
Hmm not sure if that old CGA card will work proper in a newer AT. I have an Everex Edge II (8bit MD/CGA) that works in XT, AT and even my 386 but it is from 1990+/-
There are no switches on the XL24 to lock CGA mode so it must use auto-switching and does appear to run the horizontal too fast..
Reply 2 of 17, by mkarcher
AgustinCordes wrote on 2024-07-20, 23:35:
Hi all!
The original CGA is supposed to work in any computer with ISA slots. There are videos on YouTube about an original CGA in a 486- or Pentium-class mainboard at up to 16MHz bus clock, and it still worked. The bus clock is not a severe issue for the CGA, as it generates wait states on any access. The CGA doesn't count bus clocks for the memory access timing, but works on a bus-clock independent 14 MHz clock, so it is quite insensitive to "modern computers".
If you have tools to confirm it, check the 14.31818MHz signal on the ISA connector. If that clock is missing, the CGA card will lock up the bus on the first video memory access, which would fit your symptoms.
That's a correct setting. The AT BIOS and all compatibles enable the integrated CGA support if you set the BIOS to COL 40 or COL 80.
The horizontal sync is working perfectly in your video. The vertical oscillator in the monitor is out of sync. The monitor has a V-HOLD adjustment on the back side (no need to open it) to coarsly tune the vertical oscillator. Likely adjusting the knob will make it work with the XL24.
Is it possible it [that is: the CGA card] was only meant to work with original IBM hardware?
No, not at all. Before IBM went proprietary with their PS/2 line of machines, there was no intention to make IBM cards limited to work with IBM computers only.
Reply 3 of 17, by Horun
Looks like the IBM is missing the character rom u33...when comparing other pictures.
Reply 4 of 17, by Ozzuneoj
Horun wrote on 2024-07-21, 21:07:
Yes, I don't see any pictures of this card online that show that socket unpopulated, and if the characters are in ROM, that is why the display is initializing but there is nothing showing on the screen. There are no characters to display without the ROM installed.
Reply 5 of 17, by mkarcher
That is likely the least important chip that is missing. The card on the photo also shows U5 (74S174) and U31 (74S08) unpopulated. B e careful: The "S" chips are faster than "LS" chips. LS is not a suitable replacement. 74Fxxx or 74HCTxxx will likely do as well. The missing character ROM will create a completely white screen (or whatever the foreground color of the characters is) in text mode, but will not prevent booting. I didn't check the IBM CGA schematics what the logic chips are used for, but the missing logic chips might cause a "not even beep" symptom if they are involved in the pixel/character clock generation ("wait for blank" will block if there is no pixel clock), or if they are involved in the bus timing/waitstate generation process.
Reply 6 of 17, by DEAT
I have ran my old-style IBM CGA card with a Tualatin Pentium 3 without major issues:
Re: What retro activity did you get up to today?
As for the stability issues with trying to boot into FreeDOS that I mentioned in the original post, it turns out the Apollo 133T on the mobo can't do 133FSB properly. I have a micro-ATX Apollo 133T mobo that doesn't have this issue at all, and the CGA card works great in that.
win16.page | Twitch
Reply 8 of 17, by mkarcher
Anonymous Coward wrote on 2024-07-23, 01:56:
Is it still possible to use composite mode?
Mostly yes. As the whole CGA card does, also composite mode relies on the 14.31818MHz signal on the ISA OSC pin, but as the NTSC color carrier is directly derived from it, the composite color circuit is most sensitive to inaccuracies of this frequency. The frequency is available on all ISA systems except maybe some odd 80s clones. But there might be an issue: On the original PC/XT, the frequency of that signal was fine-tunable by adjusting a varicap on the mainboard, and you could use it to make the composite colors "look right". Modern computers don't provide a way to fine-tune this frequency, so if the composite color doesn't work well enough, bad luck.
Reply 9 of 17, by rmay635703
I’m not sure if the old full CGA card I had was an ibm but it had an issue that the back part of the card hit ICs on the 386 I tested it in so it wouldn’t seat
Reply 10 of 17, by mkarcher
rmay635703 wrote on 2024-07-23, 20:11:
I also can't tell you whether your card was original, but the issue you talk about applies to the original card as well as some clone cards. The photo in the OP shows that there is no problem in the AT clone board, though (at least as long as the SIPP sockets won't get populated).
Reply 11 of 17, by AgustinCordes
Thanks all for the replies! Sorry for taking long to come back, I had notifications disabled.
mkarcher wrote on 2024-07-21, 18:44:
I'm happy to report it was the V. Hold indeed. I feel like a total dork 🫠
The attachment IMG_0333.jpeg is no longer available
The XL24 is performing admirably!
I was careful to ensure the card is plugged correctly and no parts of it are in contact with the motherboard.
The only suspicious thing that I notice, other than the missing ROM, is this wear around the lanes in the back. At least one seems to be in 'danger' zone.
The attachment IMG_0424.jpg is no longer available
mkarcher wrote on 2024-07-22, 16:50:
So the missing ROM could well be the culprit here? I'll ask the guy who sold the card to me if by any chance he has it.
Reply 12 of 17, by AgustinCordes
In fact, now that you mention it, two chips seem to be missing 🤔
Reply 13 of 17, by AgustinCordes
Sorry, I can seem to edit posts.
Two chips were mentioned in the thread as being missing, but it's actually three. Here's a new picture.
The attachment 3-chips.jpeg is no longer available
I wonder if suitable replacements can be found these days.
Reply 14 of 17, by weedeewee
AgustinCordes wrote on 2024-07-24, 18:49:
I guess you missed this
edit: wrt character rom
https://minuszerodegrees.net/rom/rom.htm <- do a search for character , there's only one line, it has 2 links, one with info one which 'chip' to use and one with the character data.
Do not ask Why !
Reply 15 of 17, by AgustinCordes
weedeewee wrote on 2024-07-24, 19:05:
You're right, I missed that bit. So 3 chips are missing:
U5 and U31, logical? I can find these locally.
U33, character ROM set. Way harder to get, at least around these parts. Sigh.
Reply 17 of 17, by weedeewee
AgustinCordes wrote on 2024-07-24, 19:24:
Just saw your edit, extremely helpful, thanks.
https://store.go4retro.com/2364-adapter/ the link from the info link on minuszerodegrees an adapter for a 27xx or 27cxx eprom
read the reviews 😀
Do not ask Why !
