First post, by DataDragons
my retro pc use awe64 with sc-55 [gameport] when i play with game like doom and duke3d sound is very good
but when i use sc-55 on new PC sound onboard with [usb/midi] doom and duke3d sound of sc-55 is very bad
what is the problem here?
Reply 1 of 11, by darry
DataDragons wrote on 2024-07-24, 04:28:
Is your USB MIDI interface an unbranded, ultra cheap one ?
Some of them are quite crappy and some MIDI devices are more sensitive to that than others.
Reply 2 of 11, by DataDragons
darry wrote on 2024-07-24, 05:12:
Yes I use unbranded one
Should I use roland usb midi? And sound will the same as my old pc?
Reply 3 of 11, by darry
DataDragons wrote on 2024-07-24, 05:35:
Before you buy anything else, could you share some recordings of how it sounds like when it's "bad" ?
Reply 4 of 11, by Joseph_Joestar
Could it be that your system is defaulting to the built-in Microsoft Synthesizer instead of using the SC-55?
I don't have much personal experience with this, but from what I gather, MIDI support is pretty terrible on modern Windows versions.
My retro stuff
Reply 5 of 11, by DataDragons
darry wrote on 2024-07-24, 05:38:
the sound doesn't come out all the way. It's lighter than usual. And the song that came out was completely distorted.
Reply 6 of 11, by darry
Joseph_Joestar wrote on 2024-07-24, 05:52:
Good point.
A quick test to either confirm or infirm that scenario would be to test by listening to the headphone out directly on the SC-55 .
Reply 7 of 11, by DataDragons
I use programs call coolsoft setup on my usb midi I’m pretty sure it’s sc-55
Reply 8 of 11, by darry
DataDragons wrote on 2024-07-24, 05:59:
How is the output of the SC-55 connected ? Are you plugging it into to line-in of your modern computer's sound card ?
Does your SC-55 model have a screen ? If yes, do you dee activity/movement on it during music playback ?
Try with headphones connected directly to the SC-55, if possible.
Reply 9 of 11, by DataDragons
darry wrote on 2024-07-24, 06:03:
How is the output of the SC-55 connected ? Are you plugging it into to line-in of your modern computer's sound card ? […]
I try with headphone the sound is better I thought it because of my usb midi
Reply 10 of 11, by darry
DataDragons wrote on 2024-07-24, 06:08:
If it sounds the same with headphones on the old and new PC, the USB MIDI is not the problem.
The problem is likely due to how the SC-55 output is connected when using the new PC.
Reply 11 of 11, by DataDragons
darry wrote on 2024-07-24, 06:11:
Sound still not good as my retro pc but when I put it on headphone the sound is just louder
