First post, by Tau-9
Looking for a most powerful PCI-X graphics, professional graphics card
(Sorry for the mistakes, I don't know English well)
Reply 1 of 14, by paradigital
I’ve never come across anything newer/better than the Matrox Parhelia. Still not a great gaming card though, but will be fine for Win9x and early XP gaming.
If you aren’t bothered about staying period correct or native PCI-X then the Startech adapter that allows the use of PCIe cards (16x slot length, 4x electrically) gives you a wider range of options.
Reply 2 of 14, by Errius
Does Parhelia have Windows 9x drivers?
Is this too much voodoo?
Reply 3 of 14, by paradigital
No. Unfortunately 2k is as early as you can go with the PCI-X Parhelia.
Reply 4 of 14, by The Serpent Rider
The most powerful PCI-X card is a PCIe GPU with an adapter.
Reply 5 of 14, by Old PC Hunter
paradigital wrote on 2024-07-27, 06:11:
Have you seen any of these adapters out in the wild? I can't find any for sale and I have three servers (4x PPro, 2x PII Xeon, 2x PIII) that I would like to test one of these adapters with.
Set up retro boxes:
DOS:286 10 MHZ/ET4000AX1MB/270 MB HDD/4 MB RAM/Adlib/80287 XL
W98:P2 450/Radeon 7000 64 MB/23 GB HDD/SB 16 clone/384 MB RAM
XP:ATHLON X2 6000+/2 GB RAM/Radeon X1900XTX/2x120 GB SSD/1x160 GB and 1x250 GB 7.2k HDD's/ECS A740 GM-M/SB X-Fi
Reply 6 of 14, by Ozzuneoj
Funny timing on the thread bump. I was just researching this subject recently.
It seems the PCI-X to PCI-E adapters are extremely rare these days, so that doesn't actually seem to be an option anymore unless you happen to stumble across one.
So, I wonder... has anyone ever tested whether the fastest known PCI-X GPU, the Parhelia, performs better in a PCI-X slot than a more modern PCI card in the same slot? Are there any modern-ish PCI cards that are capable of 66Mhz PCI operation?
Over the past year I have managed to find some interesting late PCI cards, such as a 9400GT (with 128bit memory interface) and even a Radeon HD 5450. The Radeon should be lightyears beyond the Parhelia in raw performance and driver stability... but PCI bottlenecks can completely destroy frame rate consistency, so its hard to say which would be better.
I will have to dig through my collection to see if I still have any PCI-X boards so I can do some testing eventually. I had a big huge Gateway server system about 12 years ago that had PCI-X... but I can't for the life of me remember what model it was. I just know it was a ridiculously heavy black tower with SCSI hot swap bays on the front, no AGP slot and I believe it had support for dual socket 603 Xeons. I don't think I kept the motherboard. It was so long ago though. 😌
Reply 7 of 14, by luckybob
Old PC Hunter wrote on 2025-02-11, 00:50:
get in line buddy... I want some too.
Reply 8 of 14, by The Serpent Rider
Ozzuneoj wrote on 2025-02-11, 01:13:
Regular PCI-to-PCIe also works just fine though. Still drastically better than any PCI offerings like 9400GT and works with 66MHz and potentially 100MHz.
Reply 9 of 14, by luckybob
if someone is feeling their oats, the bridge chips are still obtainable for a not-terrible cost: https://www.ebay.com/itm/125972555642
Reply 10 of 14, by Ozzuneoj
The Serpent Rider wrote on 2025-02-11, 02:19:
Has anyone showed the results of using a PCI-E card on an adapter in a PCI slot? I'd like to see a comparison of these cards: HD 5450 PCI, Parhelia PCI-X, later PCI-E card + PCI adapter. And test each on 33Mhz and 66Mhz (if the board allows it). This would answer a lot of questions.
Also, just to be clear, without some funky cobbled up setup, a low profile card would have to be used so that the adapter + card still fit in a standard PCI slot location.
I found this thread but it doesn't actually provide any gaming results in the end once the issues were worked out:
GTS 450 + Dual Tualatin.
Reply 11 of 14, by luckybob
i have some stuff coming from china (eventually). but i dont expect any performance issues
Reply 13 of 14, by CwF
I do now for sure that a HD5450 PCI runs fine on 66 MHz.
I used to know what I was doing...
