Reply 480 of 1179, by nd22
50%!!! That is the advantage nforce2 has over nforce1. Incredible, isn't it? And that is at 1600*1200 with AA and AF! Also nforce2 kills KT266A at the same resolution with a 24% better results! It is clear that by changing the motherboard to an nforce2 ultra one a massive leap in performance will be obtained that otherwise would not be possible with, for example, a better graphics card.
