First post, by zaphod77
Not to be confused with BALLADE.MID, JAZZ.MID, MINUET.MID, and REGGAE.MID. 😀
i've litereally found ONE recording of each of these on the net.
https://www.vgmpf.com/Wiki/index.php?title=Ballad_2
https://www.vgmpf.com/Wiki/index.php?title=Reggae_2
https://www.vgmpf.com/Wiki/index.php?title=Jazz_3
https://www.vgmpf.com/Wiki/index.php?title=Minuet_In_G_Major
Anyone have a way to get these to playback right on modern systems withotu actually runnign windows 3.1 and installing those old pre general midi sound drivers?
(yes these midis use a non gm compatible instrument map that was used in the old dos voyetra sequencer, and the old dos SB music FM driver, that also wodl play these exact same midis).
I remember trying to fix these midis by hand way back in the day, because the NEW gm compatible windows driver broke them, and they just sounded wrong. For example, the grand piano instrument needed to be changed to Bright Grand Piano to get the piano to sound right, and that wasn't the only change needed.
I'm sure that if i can get my hands on the 2 and 4 op super sapi banks and load them into libadlmidi somehow. I can play these back right.
Reply 1 of 14, by zaphod77
Anyone at least have the darned instrument map? I've been trying to find a copy of the sequencer with the pre-GM instrument mapping in it, and failing completely. also the versions i've found so far have the 4op drivers, and i want the 2 perator bank. the midi files itself for ballad2 is no help, just calling the non piano non bass track "Melody", and it's most definitely not the pan flute used for ballade.mid
Reply 2 of 14, by NJRoadfan
The following file might work (came with the driver). If you have the SuperSAPI! Windows drivers installed, load it via the palette selection screen. Tested it and it seems to work, canyon.mid is noticeably less rich sounding. You will get confirmation of "128 Patches Read" by the driver after loading.
Reply 3 of 14, by zaphod77
if it's the real old patchset, canyon will sound horribly metallic and dissonant.
but what i want it the number to patch names, but the actual audio, so i can adjust the patches to normal GM.
Reply 4 of 14, by NJRoadfan
Based on what I've...heard...that's about right. WIndows FM MIDI drivers almost always map to GM instruments by default. Given the samples were recorded under Windows on that site, one can assume the MIDI files are GM, or close to it. The SuperSAPI! driver is exclusively an OPL3 driver since it supports stereo and 4OP modes. There may be an earlier revision of the driver that came with the dual-OPL2 SB Pros (different register layout, no 4OP, and limited stereo). Maybe the 2OP palette approximates this with the OPL3 driver?
Reply 5 of 14, by NJRoadfan
The recordings on that site sound close to the default Windows OPL driver, aka the Yamaha reference driver that uses The Fat Man patch set. This is the same OPL2/3 driver that comes with Windows 9x. OK, not quite, the drums are definitely the Voyetra patch set. I'm going with an early Voyetra Windows driver for those, I just have to find it.
Reply 6 of 14, by zaphod77
there's an old windows 3.0 driver, and a newer one.
the old one didn't use a GM compatible instrument mapping.
these four midi files came with sound blaster and sound blaster pro, and played correctly with those drivers only, and not with the newer updated GM compatible drivers.
the versions that game with later drivers were without the numbers at the end of the filename, and had different mappings that were more GM compatible, but did NOT sound the same. Reggae's melody is an octave lower than reggae 2 and the instruments are different, ballade uses pan flute instead of whatever chromatic percussion the version i'm talking about sounds like it's using (though the bass was corrected to fingered bass instead of saxophone 🤣), and jazz while most similar still sounded better as jazz3 on the old re GM drivers.
As i said, i want that non gm patch list, so i can remap the instruments correctly, and then play them on fat man 2 op or the voyetra gm 2-op patchsets, and then try it on real synths. my copy of sequencer plus pro has the gm 4-op opl3 driver, which definitely sound different from the two op, and thus can't be used to id the patch by trial and error. The fat man 2-op doesn't actually seem to have that instrument, though a number of them sound similar.
I strongly suspect that the instrument was intended to be vibraphone, judging by the tremolo present that exists on a real vibraphone with the fan on, but i don't have access to the voyetra 2-op patchset in adlplug to mess around with.
If someone can find me that bank in wopl format or something else adlplug can load, i can probably get my answer.
Reply 7 of 14, by zaphod77
ok, i figured out the darn instrument mapping. it's MT-32. because of course it is. That's the pre gm standard, of COURSE it was that.
therefore, ballad 2 uses warm bell, which translates as tubular bells according to SCUMM, which is really darn similar in the fat man 2 op patchset, and probably identical in the voyetra 2 op one.
so those four midi files are actually composed for the mt32 instrument mapping, which has acoustic piano three instead of electric grand, which explains why it's not right. and the bass is suposed to be accoustic bas, not fingered electric, so that's wrong in ballad.mid as well.
so, mystery solved. 😀
Reply 8 of 14, by NJRoadfan
Somehow I suspected that. I have a few other MIDI files that were composed for the MT-32 that I managed to sound "decent" on OPL3 by changing the instrument mappings. The MIDI Mapper in Windows 3.1 allows you to set custom patch maps as well. The built-in MT-32 and EMU Proteus "drivers" do this for you. Those mappings get erased when you install a 3rd party driver though since Microsoft never setup a way to programmatically add new MIDI maps. All drivers just copy a whole new MIDIMAP.CFG file!
Reply 9 of 14, by zaphod77
also it seems that what i really want is a (virtual) sound canvass in mt-32 mode to play those midi files on, as those GS devices have many of those instruments that were on mt32 and not on general midi, like the 303 acid bass and dr. solo, presumably one of them is "warm bell", though i have no idea which.
Anyone have the instrument mapping for a high end sound canvas mt-32 mode? with that, i can remap those midis to GS mode.
Actually, anyone have a FM 2op and 4op GS patch set? 😀
Still want the 2 op drivers for sequencer plus pro, and i can't find them. there doesn't seem to be a TAPISB.COM anywhere, and no amoutn of mesing with vpi and sapi gets them to operate on my copy of sequencer.
and wow. so warm bell IS included in an actual sound canvas in bank 127, but it's a combination of two other voices, and of course the manual doesn't say which one. And it's NOT included in any of the GS maps. what the heck, Roland???
so i just need to set CC00 to 127 in the midi file, and then they should play back correctly on roland devices that actually have the mt-32 mode.
Reply 10 of 14, by zaphod77
finally figured out how to get seq plus gold to operate. but even with the opl2 sapi drivers (either version) they still don't have a patch that sounds like their mt32 one.
the hunt for the mt-32 fm bank continues...
Reply 11 of 14, by zaphod77
Okay i've found the fm bank (finally)
sbtimbre comes with a melody only version of it (mt32.ibk), and so does the creative mid2cmf.exe (melody.ibk, with lousy instrument names)
mid2cmf also comes with a drum.ibk, but all my attempts to actually use it outside of mid2cmf fail.
both melody banks seem to work fine with libadlmidi.
Reply 12 of 14, by dormcat
Guys, thank you so much for solving a mystery that has been bothering me for three decades! 😂
When I had my first SB Pro 2 (still works today!) and Windows 3.1 in the summer of 1992 as a gift of starting high school, I noticed that after installation using the floppy disk there were two directories under \SBPRO, MIDI and PLAYMIDI, with similar but different MIDI files:
The attachment SBP_FD.jpg is no longer available
The attachment SBP_FD_files.jpg is no longer available
Playing \MIDI files under Windows 3.1 with MMJBOX.EXE (with a grey jukebox icon) sounded fine, but \PLAYMIDI files sounded weird, almost like broken. I didn't pay much attention as long as the former set of files worked well.
A year later I got the Multimedia Upgrade Kit for SB Pro:
The attachment SBP_CD.jpg is no longer available
The attachment SBP_CD_files.jpg is no longer available
The CD contains a complete Windows 3.1 under \WINDOWS and all SB Pro drivers and programs under \SBPRO, respectively. However, the CD-ROM only had \PLAYMIDI directory and files (with PLAYMIDI.EXE a little bit larger), while MMJBOX.EXE now looks like a phonograph with a large floral-shaped speaker (unlike any jukebox at all!). The old grey jukebox would crash under Windows 3.1; old \MIDI files sounded broken, while \PLAYMIDI files sounded acceptable but not as good as the old ones. It's now clear that those \MIDI files, as well as the early batches of SB Pro hardware, were a year older than Windows 3.1 (released in April 1992).
So those files were made with MT-32 mapping; hope I'll be able to hear them using MT-32 one day, as working MT-32 hardware is now prohibitively expensive nowadays. 🙄
Reply 13 of 14, by zaphod77
Here's ballad2.mid on Munt. 😀
https://www.youtube.com/watch?v=cYGVkBXByv4
That's the one that suffered most from being converted to GM.
I should also do reggae2, but i'm not sure that one is actually improved.
Reply 14 of 14, by zaphod77
So i figured out how to throw nuked-sc55 into mt32 mode, and ballad2.mid sounds BETTER on it than an actual mt-32.
press q. hold y and press q, press w. play your mt-32 midi that uses default instruments.
Still lousy mt-32 piano, but it's balanced better. And yes, the only way to get this sound out of a sound canvas is to throw it into mt-32 mode, as "warm bell" patch does not exist outside of it.
