First post, by edescourtis
I’m looking for the fastest CPU in the world for Real Mode operations specifically for running MS-DOS. I understand that Real Mode is quite slow on modern CPUs, but I’m curious to know which CPU performs best in this mode. Can anyone provide insights or benchmark results comparing different CPUs in Real Mode? Recommendations on DOS benchmarking software or tools that can accurately measure and compare CPU performance in Real Mode would also be greatly appreciated.
Reply 1 of 90, by edescourtis
For benchmarking, does anyone have results from the following tools?:
• Norton SysInfo
• Landmark Speed Test
If you have any benchmark results from these tools, please share them.
Reply 2 of 90, by Cyberdyne
Modern CPUs are just more ineffective in 16bit real mode, but not slower than a Tulatin or a Athlon XP or even Core2, that I concider the last "classic" cpu. After that they started to remove legacy functionalities.
Reply 3 of 90, by edescourtis
That's what I think, too, but it would be great to see benchmarks confirming this.
Also, how do you know what the fastest MS-DOS 16bit real mode CPU in the world is? Is it simply the fastest single-threaded modern x86 or are there differences between manufacturers? How to the fastest optimized 16 bit real mode CPUs compare etc…
Reply 4 of 90, by Ringding
Under virtualization or bare metal? I don’t know if there is a difference, just asking. My 8th gen Intel chip is plenty fast under virtualization, and I have never tormented it, nor do I plan to, with real real mode.
Reply 5 of 90, by digger
Wasn't the Netburst (Pentium 4) architecture less efficient than Pentium III without special compiler optimizations? Wasn't that the reason why they actually went back to the Pentium III architecture (or a variant of it) in the form of Pentium M (Banias/Dothan) after the P4 couldn't scale in performance, particularly in an energy-efficient way?
I guess it would be interesting to compare real mode (and 32-bit protected mode) DOS benchmarks between those architectures, as well as later ones, to see how legacy mode peformance developed.
Reply 6 of 90, by Cyberdyne
But measurements should be operation per megabyte also. Not just raw power.
Reply 7 of 90, by ludicrous_peridot
When I compare CPUs for DOS these days I run PI by @Rayer and just check the time elapsed.
Would be curious to see what you folks get in terms of time of computation on those fabled Athlons of old.
One other benchmark I could think of is using Doom (e.g. MBF, I think, has sufficient capabilities for that), but personally I don't even go there.
GA-G41M-Combo G41/ICH7 - Core 2 Quad Q9550 - DDR3 1033 - Radeon RX570 - CMI-8738 - X3MB - CM-300 - Saitek ST-30
Beetle/M/i815+ICH2 - Celeron 566Mhz - Opti 924 - YMF740 - MT-100
https://archive.org/details/peridot-26
Reply 8 of 90, by oldhighgerman
Well in terms of a chipset that can natively run Win2k and perhaps NT,98, etc., and may be able to boot a dos disk (can't swear to it though), consider a socket 771 motherboard. At least 1 has a floppy controller on board, Supermicro.
This might lead someone to ask whether socket 775 are equally capable and as fast. 771 and 775 mobos both can have dual cpu's. Not that it would benefit real mode performance (don't think anyway).
Reply 9 of 90, by ludicrous_peridot
Appreciate not exactly what the OP has asked for, but here are couple systems I run PI against today.
Don't have the OP mentioned benchmarking tools though...
Spoiler
CPU name: Intel(R) Core(TM) i5-4210U CPU @ 1.70GHz
CPU ID: 40651 - type: 0 (primary), family: 6 (P6), model: 5, stepping: 1
CPU cores: 2/4, turbo speed: 2700MHz = 27.0*100MHz; L1 cache = 64kB, 8-way
DB CPU name: Core i7-45x0U Haswell, FC-BGA 1168, 22nm
Calc finished with 64000 digits, execution time: 22.81 sec.
CPU name: Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
CPU ID: 10677 - type: 0 (primary), family: 6 (P6), model: 7, stepping: 7
CPU cores: 4, nominal speed: 2833MHz = 8.5*333MHz; L1 cache = 64kB, 8-way
DB CPU name: Core 2 Quad/Xeon Yorkfield 2333-3200, LGA 775, 45nm
Calc finished with 64000 digits, execution time: 14.86 sec.
Reply 10 of 90, by Ringding
This PI calculator runs in 32-bit protected mode
Reply 11 of 90, by ludicrous_peridot
Apologies, have overlooked this; and from description and trying it in DOSBox, it's compiled for later CPUs, so not quite a universal comparison tool, so my bad.
Reply 12 of 90, by Falcosoft
For testing I can recommend earlier AIDA16 versions that still have the 'Benhcmark' menu option with MIPS16 and MIPS32 sections. AIDA16 also gives a 'Pentium rating' at each banchmark section so you can compare microarchitectures in case of both 16-bit and 32-bit code.
From the Pentium Pro/PII the trend is that all x86/x64 microarchitectures are much faster in 32-bit code than in 16-bit code (compared to a baseline P5 100 MHz CPU).
AFAIR the K6 2/3 line from AMD was the last x86 microarchitecture where 16-bit code was nearly as fast as 32-bit code. But of course this does not mean that a K6-2 at 400 MHz would be faster in case of 16-bit code than a Core I7 at 3Ghz.
This just means that e.g. an Ivy Bridge Core I7 at 1 GHz performs as a hypothetical P5 500 MHz in case of 16-bit code but performs as a hypothetical P5 3 Ghz in case of 32-bit code (while a K6-2 400 MHz performs as a hypothetical P5 500 MHz in case of 16-bit code and as a P5 550 MHz in case of 32-bit code).
The attachment Aida16.zip is no longer available
Website, Youtube
VST Midi Driver Midi Mapper
Reply 13 of 90, by zyzzle
ludicrous_peridot wrote on 2024-07-27, 12:47:
I can see no program called PI on RayeR's homepage. May you please provide a link or attach that program here?
An excellent DOS program which calculates Pi to large numbers of digits is Carey Bloodworth's PiAGM version 2.4
Reply 15 of 90, by Dothan Burger
edescourtis wrote on 2024-07-24, 13:14:
For benchmarking, does anyone have results from the following tools?: […]
• Norton SysInfo
I compared two systems because they are so close; Core 2 Duo T7600 2.33 GHz Merom vs Core i5 520m 2.4 GHz Arrandale.
Aida16
Core2 1096 - Core i5 1108
RayeR's PI
Core2 24.82 - Core i5 20.31
I was interested in testing this because the Core i5 was going to replace the Core2 in my ultimate 98 system but it scores 200 realtics lower in Shareware DOOM. Is DOOM shareware a 16bit application?
Reply 16 of 90, by Falcosoft
Dothan Burger wrote on 2024-07-29, 22:39:
...Is DOOM shareware a 16bit application?
No, DOOM is a 32-bit protected mode application (the shareware version is not different from this aspect).
Website, Youtube
Reply 17 of 90, by Dothan Burger
Falcosoft wrote on 2024-07-29, 22:53:
Thank you! I wasn't sure how to find that out.
Is realmode achieved by restarting into ms-dos mode and running Aida16?
Reply 19 of 90, by BitWrangler
I'm gonna go with the interpreted Basic and compiled basic versions of the whetstone on Roy Longbottoms pages for clues, the efficiency table here, first two columns only of results are 16 bit I think, http://www.roylongbottom.org.uk/whetstone.htm#anchorPC3
Which makes it look like Phenom II might be the one to beat, needing near 6 Ghz of intel core to best it at 3Ghz, and the Phenoms will go to 4Ghz on air given a bit of luck and 6 or 7 ghz with cryogenic liquids. So unless you can get over 6 ghz on air on recent core i-doesn't-matter-it's-single-core, or 12 Ghz or so with LN2 I think it will be the phenom II.
