First post, by Kordanor
So far I have only used soundblaster/adlib. This is what I used in the past, and this is also what I mainly want to use in the future.
However, there are games which really struggle with Soundblaster/Adlib. One of them is Might and Magic 3. In MM3 Soundblaster/Adlib just doesnt produce any good combat sound. While the music is fine, all combat sounds are immediately cut off. This can be seen on real hardware as well as on emulation (the game also has some speed sensitivity where a good setting is basically impossible, but if you slow it down in emulation to a hold basically I think the sounds are getting a bit longer).
On Roland however it sounds perfectly fine.
So I was thinking about my options of getting Roland running (I am not actually familiar with the different descriptors and the exact differences between Roland MT32, Roland LAPC-C and MPU-401).
Getting a soundcard which can do that doesn't seem to be a big issue. I was thinking of buying an Orpheus 2 LT anyways to get rid of ISA noise on my SB card, and this one also comes with MPU-401 (210€) not exactly cheap I see the MPU-401 as added feature there. Alternatively there is the PCMIDI for 110€ which I think features the same hardware minus the SB stuff.
I also saw the PicoGUS, which, as well features MPU-401. This is emulation and can be had for like 65€ (plus added costs I guess). And for emulation just on the "sound end" would be fine with me (I still want to a vintage PC).
But even though the part in the PC can be had for a decent price, a roland mt32 goes on ebay for 300€ or more, which would be quite an investment. So I am wondering if there are any cheaper alternatives. Like where instead of a Soundblaster from Creative I am using an ESS Soundcard which is just compatible. Are there cheaper alternatives for the roland mt32?
I am also aware that there are legal problems with how it sounds, which is why it's not actually included in the official DOSbox. So I guess that's another can of worms if you want to get it done legally.
Do you have any advices there?
Will these 2 cards even work on MM3 as it wants a Roland LAPC-1?
