MikeSG wrote on 2024-08-07, 05:42:In Bios:
DRAM Slow Refresh adds ~5% performance
CPU Burst Write adds performance […]
In Bios:
Don't know about 67MB/s, but for L2 ~50MB/s is normal for 33MHz bus. 25-35MB/s RAM. In CacheChk not Speedsys.
Revisiting this agree with above
Similar situation here but different board
486 cache/ram speed issue with write-back
Burst should be enabled
Slow refresh enabled
L1 should be write through
L2 should be write back
Once he does this retest.
His pod might be overclock able to a 40mhz FSB if he does the regulator mod which would also be interesting to test.
Once upon a time I had a board with the stupid simple bios he has and fastest wasn’t actually the fastest (upon testing)
So he will likely have to run through all the setting combinations including auto to see what type of memory speeds he can get with the board configured in all the different ways.
If I were him I would install an AMD 5x86 and run the memory and cache tests then do the same for the p24t.
Some 486 board/bios combinations gimp the p24t compare to normal 486 chips
