First post, by Tyrhus
In a previous post I revived a non posting Intel MB.
Now I have another problem, the L2 cache isn't detected in bios nor by utilities such as cachechck or speedsys.
I use 32mb of Edo ram.
Inside the bios external cache is written as n/a and the cache page only allows me to enable the internal cpu cache.
I tried tweak bios but I can only alter l2 timmings.
Edit:
Altering L2 trimmings and tweaks in tweak bios result in different memory scores in cache check, from 61mb/s main memory to 73mb/s
Could it be that it's working but not detected?
Also the cache chips seems cold to the touch.
What should I investigate?
Running benchmarks I get 50fps in doom and 24 in quake
