Reply 380 of 574, by BinaryDemon
javispedro1 wrote on 2024-08-12, 09:16:The p386 does NOT support LBA, so you cannot exceed this 8GiB limit with any DOS version, nor 9x. Other non-DOS bases OSes like Linux or NT may be able to exceed the 8GiB limit (booting it being a problem...). Another workaround would be to use a DDO, or a custom BIOS.
Doesn’t support LBA at all? Bios seems to be LBA aware and bootup indicates an LBA status.
I just assumed it was an early implementation (pre-LBA22?).
