First post, by Crinale0
So I just got a CRT for my retro rigs, I've not used a CRT probably since the early 2000's so maybe that is it but I really am at a loss as to why my CRT looks so much worse? I have a basic 19 inch HP LCD and it looks so much better than this CRT.
What am i missing? Even the black levels are better on the LCD which is one of the best points of a CRT isn't it? Is it just my eyes being used to LCD after so long? Is my CRT garbage? Is it the reflections from outside? I'm so confused. I'm running at 800x600 75Hz on the LCD and 800x600 85Hz on the CRT.
I don't really understand whats going on. My LCD seems to be worlds apart from my CRT and its a cheap ex office HP LCD. I also noticed Windows looks really crisp on the LCD whereas the CRT looks blurred.
Thoughts?
Athlon XP 2400+ @2Ghz|512MB DDR RAM|QDI 7X/400|PNY Geforce 4 Ti 4200 128MB w/ AGP 8x|Sound Blaster Live
Reply 1 of 9, by dominusprog
Well, it depends entirely on your taste. CRTs have a much better contrast compared to LCDs, but maybe your CRT needs service.
Reply 2 of 9, by Shadzilla
Have you played around with the brightness and contrast settings on the CRT? I find they look best in a slightly darker environment too, and definitely without any light sources in front of the screen.
Reply 3 of 9, by Crinale0
dominusprog wrote on 2024-08-20, 17:42:
I think you are correct as it's now developed a fault where it turns off by itself and flashes an orange light. CRT's + mail service... don't ever consider it!
Reply 4 of 9, by Unknown_K
Probably needs calibration.
Reply 5 of 9, by Namrok
Don't feel too bad. It has gotten exponentially harder for me to find CRTs from even 6 years ago when I started. Used to be if I was patient, I'd see someone giving one away every 3-6 months. Haven't seen that in years. The ones I do find tend to have issues that have thus far proven beyond my ability to fix. It does seem we are approaching the last days of the CRT. Probably not this year, or even the next. But I'd be shocked if many people, even enthusiast here, have working CRTs in 10 years.
I hope I'm wrong though. Or someone makes a 4:3 OLED panel.
Win95/DOS 7.1 - P233 MMX (@2.5 x 100 FSB), Diamond Viper V330 AGP, SB16 CT2800
Win98 - K6-2+ 500, GF2 MX, SB AWE 64 CT4500, SBLive CT4780
Win98 - Pentium III 1000, GF2 GTS, SBLive CT4760
WinXP - Athlon 64 3200+, GF 7800 GS, Audigy 2 ZS
Reply 6 of 9, by Crinale0
Namrok wrote on 2024-08-20, 20:27:
To be honest, I think you may be right. I used to be into the arcade scene and all their CRT's were dying to the point of no repair possible... They could often service the chassis but the actual tube or neck... Not really. I had 2 Ridge Racer arcade cabinets in the past (x1 deluxe with a Hantarex Polo 2 32" CRT in, x1 stand up model with a 25" Hantarex Polo 1 CRT) the deluxe's CRT tube died on me in the mid 2000's and i scrapped it. My other one the screen's chassis crapped out due to age, got it serviced and the tube went so i sold it that was around 2018.
New old stock tubes came up now and then and commanded INSANE prices and this was around 5 years ago. I can't imagine what they would fetch now. Most of their CRT's were from early 80's cabinets most often so it kinda gives you an idea of when they really will be gone. I doubt CRT tech changed much over the years or got more reliable but i could be wrong. Certainly wasn't any better in my cabinets.
Either way, I'm sticking to my 19 inch LCD now as the CRT is not very well at all and I'm not prodding around in it, PSU's and CRT's are things i just don't tend to mess with and for good reason.
Reply 7 of 9, by StriderTR
If it had not developed another fault, I would has said what others said already, that perhaps it needed to be adjusted or serviced. Sometimes, the CRT itself may have just seen a lot of use and no longer works as good as it used too.
That being said, while I would not mind having a CRT or two around to play with for pure nostalgia, I'm also not looking for any. I have a working Dell 4:3 LCD that works good, looks good, and takes up much less space and doesn't weigh a ton. As much as I love reliving the 80's and 90's, some of that older tech is just getting too hard to find and maintain, so I gave up on CRT's quite a while ago, and like you, old power supplies as well. With PSU's, there really is no reason to use an old one when there are modern alternatives or can be adapted to work in most all cases. I tend to try and focus more on the core components (MB/CPU/RAM/Video/Sound) over the power or externals.
However, I will admit, if I had unlimited free time,that would probably be a different story. I would try and save as much of it as I could. Sadly, that's just not the case. 😀
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Reply 8 of 9, by GemCookie
Crinale0 wrote on 2024-08-20, 15:29:
Ding ding ding! The surface of a tube is much brighter than that of an LCD panel. The former will compare a lot better in a dark room.
Some video cards (such as my GTX 750 Ti) upscale the current resolution to the maximum supported by the monitor. This is less noticeable on LCDs, since they have to upscale lower resolutions anyway.
CRT monitors can also display a fuzzy image at high refresh rates.
Gigabyte GA-8I915P Duo Pro | P4 530J | GF 6600 | 2GiB | 120G HDD | 2k/Vista/10/Debian
MSI MS-5169 | K6-2/350 | TNT2 M64 | 384MiB | 120G HDD | DR-/MS-DOS/NT/2k/XP/Gentoo
Dell Precision M6400 | C2D T9600 | FX 2700M | 16GiB | 128G SSD | 2k/Vista/11/Gentoo
Reply 9 of 9, by Griff3125
My CRT's have always had a brighter, sort of phosphor grey look over my LCD's, I was never really impressed with the black level(s).
What did impress the hell out of me was the absolute liquid smoothness of the CRT, especially in the older FPS games, everything just seemed to flow so effortlessly, like water on ice.
I'd compare screens of Quake 1 side by side, move left to right, it was just beauty in motion, LCD=Sandpaper, CRT=Water.
And the depth perspective and perfect rounded pixels were much better for me on my 18" Princeton CRT then my gaming LCD.
But honestly, the geometry issues, the heat generated and the space the CRT took up, just was not worth it in the long run.
