First post, by tsalat
Hi guys,
I got a few boards that are not working, again, and I am struggling to make them work - some were repaired but some are beyond of what I know so far.
One of them is a good looking ACER 286 - I believe is the one on the link below although the jumper position is not absolutely the same in the manual and the board. I have enclosed the pictures of the board.
https://theretroweb.com/motherboards/s/acer-r … -286-12-16#docs
The board will not show anything on the post card but it starts and returns the beep codes, without a GPU I am getting the missing GPU code, with the GPU - no picture - I hear the RAM check beep codes.
The board a bit of damage around the battery but I could not find any broken traces there. The OSC are outputs fine. and the CLK and OSC ISA pin gets a good signal.
All address and data pins from the ISA slots are outputing but the pin A19, Adr 12 outputs at the beginning and then signal disappear. The resistivity on all address pins is the same, around 168ohms.
I am not sure what to check next, I have tried the BIOS that outputs just the CPU ID, nothing on the post card.
any idea what to try next or how to debug anything that could cause this?
thx, tomas
