First post, by sketchus
I vaguely remember this working a few years back but I wanted to just check to make sure I'm not doing anything ridiculous...
So far I my plan is to run my PCI Turtle Beach A3D 2.0 as my main Windows 98 card.
I also have a Yamaha Audician 32 Plus as my ISA card, that I plan for DOS use.
Now here's the thing, it's been a long time since I've done this, I remember in Windows 98 you can fairly easily just select which card you want to use, DOS is where I'm blanking. Is it best practice to install all drivers, or only the ones required per usage environment?
Apologies if it's more simple than I'm making out.
