First post, by Crinale0
I've been trying to fit a mouse to my Windows 95 / DOS machine. It has a serial port but thats it. I got a serial to PS/2 converter and a conventional ball mouse as to my understanding serial isn't able to power optical mice?
This has not worked. So i looked in the board manual and it has a USB header! I added a dual port USB to the header, enabled USB controller in the BIOS and legacy USB keyboard support yet still nothing.
What am i missing here? I am using the Windows 95 version with USB support. I have tried add new hardware it does not find a USB controller nor a mouse. Over serial to PS/2 is does detech a PS/2 mouse but upon installing drivers the mouse does not work.
Ideally I'd like to use a USB optical mouse on this machine as ball mice are a nightmare and i have large hands and need a specific brand of mouse to be confortable. That said though, PS/2 would suffice.
Athlon XP 2400+ @2Ghz|512MB DDR RAM|QDI 7X/400|PNY Geforce 4 Ti 4200 128MB w/ AGP 8x|Sound Blaster Live
Reply 1 of 13, by dominusprog
Remove previously installed USB supplements and install the eXtended USB supplement. But I believe that it works only with flash drives.
https://archive.org/details/XUSBSUPP
Reply 2 of 13, by pyrogx
USB input devices don't work on Windows 95, only with Win98 onwards.
If you need to use a USB mouse, a PicoGUS card is now able to emulate a serial port for a USB mouse.
Reply 3 of 13, by dormcat
Crinale0 wrote on 2024-08-23, 13:10:
I can use Microsoft Basic Optical Mouse (USB) under DOS 6.2 (mouse.com 8.20) with a green USB to PS/2 converter that comes with just about every Microsoft USB mouse. I also have a Logitech optical mouse with native PS/2 connector and an earliest generation of Artec optical mouse with serial connector that requires a metallic reflector plate with grids (very similar to Mouse Systems mice for Sun; almost like a clone). They function normally on my 430FX and TX boards. Therefore I don't think "serial isn't able to power optical mice" is true; all three major interfaces can power optical mice. Know that serial ports today still power many industrial devices with light sources and optical elements e.g. handheld barcode scanners.
Your Soyo SY-5VD motherboard does have a PS/2 header (J1) right next to its DIN-5 keyboard connector (J2). You might want to try that first instead of using the USB header; finding a PS/2 cable for that header could be more challenging, however. Unfortunately this was a common problem of many 430VX/TX boards in Baby AT form factor: they were ready with PS/2 and USB headers but either required user to purchase the cable or lost them after a quarter of a century. Therefore I really appreciate the standardization of ATX I/O panel.
Reply 4 of 13, by Joseph_Joestar
dormcat wrote on 2024-08-23, 15:21:
It's pretty easy to rewire these PS/2 brackets to fit whatever header the board has if you use DuPont jumper wires. Determining the pinout of the header is a bit trickier if it isn't specified in the motherboard's manual.
Anyway, here's a nice video from a fellow Vogons user on this subject.
Reply 5 of 13, by Crinale0
Thank you all for the advice you guys are awesome!
I REALLY need a PS/2 header that is the perfect solution. where can i buy one? I don't really have the tools to make one.
Reply 6 of 13, by dormcat
Joseph_Joestar wrote on 2024-08-23, 15:32:
That was why I called it "challenging" as the manual had no detailed pinout. An opposite example would be my Asus TXP4 manual:
The attachment TXP4_PS2.jpg is no longer available
I don't have the optional USB/MIR module in the photo; instead I only have the default parallel + PS/2 bracket. A PS/2 port uses pins 6, 7, 9, 15 for clock, ground, +5V, and data, respectively.
Wow I think you've nailed it: the pinout at 3:24 looks exactly like the one on Soyo SY-5VD.
The attachment PS2_header.jpg is no longer available
Reply 7 of 13, by Shponglefan
Crinale0 wrote on 2024-08-23, 16:47:
CablesOnline has them. I bought some from them via Ebay.
Note that they are pre-wired, so if you need to change the pinout you'll have to modify them by hand.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 8 of 13, by Crinale0
Thank you so much guys! It's insane how quick you find this information haha!
That said, I'm looking for a plug and play fix for this ideally, does anywhere sell PCI PS/2 boards or ISA ones?
Reply 9 of 13, by dormcat
Shponglefan wrote on 2024-08-23, 16:54:
Also found one with PS/2 and parallel on the same bracket from PCCables. The PS/2 connector is 2x4 and has one unconnected hole sealed for fool-proof, probably designed exactly for headers like Soyo's. I still recommend performing a continuity test, though.
Crinale0 wrote on 2024-08-23, 16:58:
PS/2 on ISA:
PS2 port ISA card?
Another PS/2 Mouse ISA (ISA8) card adapter
PS/2 on PCI or PCIe x1 are readily available for purchase at many commercial venues.
Reply 10 of 13, by Crinale0
Do you have a link to one in PCI form please?
Reply 11 of 13, by dormcat
Crinale0 wrote on 2024-08-23, 17:41:
First, Google is your friend. Second, according to other VOGONS users those cards were driver-based and might not work well without OS support.
Reply 12 of 13, by akimmet
I don't reccomend the PCI cards with PS/2 ports on them. Most of them claim that they are incompatible with DOS.
Reply 13 of 13, by jakethompson1
A PS/2 mouse interfaces with your motherboard's keyboard controller; that's why the port has to be directly on a board or on a dedicated header. There isn't a way to connect to the keyboard controller through the slot connector. The dedicated header is really your solution, and pinout differences aside, will solve this for you once and for all. It isn't that bad, the rearranging wires part in the connector just involves a tiny screwdriver/tweezers to release the part that grabs onto the wires without breaking it, so that you can reinsert the wire colors in a different order.
