First post, by Tomek TRV
Hi
Can somebody inform me how to measure CPU supply voltage on Socket 370 without installed CPU? Supply voltage is somehow regulated when CPU is installed because it may be different for different models of CPU. I just replaced capacitors on one mobo and CPU is getting hot quickly so I would like to measure voltage but without CPU it is impossible and I don't want to burn my CPU. It would be good if I can cheat VRM to get any voltage.
Reply 1 of 3, by Horun
We need to know the motherboard make + model to point you which inductor or Mosfet to measure from to ground. The VRM reads the VID from cpu (if not jumpers/switches) so it would be hard to fake with something else.
It only takes a few seconds to get a volt reading if you set things up proper (have meter ground in a black atx psu lead, have red lead touching proper point with one hand and push power on with other hand, etc)
added: as a estimate most P3 soc 370 coppermine run around 1.7v core and tualatin run about 1.5v core.
Reply 2 of 3, by shevalier
Tomek TRV wrote on 2024-08-24, 21:48:
Place a piece of wire into the socket and connect Vid4&Vss - AK36&AM34 = 1.3V
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 3 of 3, by Tomek TRV
shevalier wrote on 2024-08-25, 04:29:
Thank You. I started searching for socket 370 pinout to find where are these pins You wrote about and I found this:
https://www.overclockers.com/voltage-mod-for- … the-wire-trick/
So now I am sure that I have correct CPU supply.
Слава Україні!
