First post, by TheFriedLemon
I have installed a SiI 3512 based pci sata controller card in my DFI PB61-ZX motherboard (A 440ZX motherboard with award bios 4.51PG) and it doesnt seem to be detected at all as a device.
When i install it on my Intel BI440ZX motherboard (A 440zx motherboard with ami bios) it detected and can also be used as a boot device to boot sata device.
(both of the boards have the same chipset, so the chipset isnt the issue)
Is there any solution/patch for this issue?
Reply 1 of 18, by Many Bothans
In building out my AOpen AP43 system, I ran across numerous PCI cards with universal keying that were just ignored by my 5v only PCI slots.
It is possible that SATA card only works on 3.3v even if the card is keyed universal. The DFI may only be wired up for 5v where the Intel has both voltages to the slots.
  • Zenith Z386SX-20, 8MB FPM, Video 7 1024i, Unhoused
  • AOpen AP43, Am5x86-133@160, 1MB L2, 128MB FPM, Stealth III S540 32MB Savage4, SB32
  • ITX-Llama, 3Dfx V3
  • Asus CUV4X-E, P3-933, 512MB PC133, Hercules 3D Prophet II MX 32MB, SB Live!
Reply 2 of 18, by TheFriedLemon
Many Bothans wrote on 2024-08-28, 02:17:
it has 2 notches and the rear part of the card is missing like 4 pins in each side
Reply 3 of 18, by shevalier
yep, ST-LAB A390
image;s=1000x700
Near the bracket there is no regulator U2 from 5V to 3.3
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 4 of 18, by TheFriedLemon
shevalier wrote on 2024-08-28, 05:46:
yep, ST-LAB A390 https://ireland.apollo.olxcdn.com/v1/files/dlzoiikvvusu-UA/image;s=1000x700 Near the bracket there is no regula […]
yep, ST-LAB A390
image;s=1000x700
mine is a SWEEX PU102
next to the bracket it looks as if its missing a cap and some 8 pin chip
Reply 5 of 18, by TheFriedLemon
TheFriedLemon wrote on 2024-08-28, 06:47:
yep, ST-LAB A390
image;s=1000x700
oh well, its missing a regulator too, its just hidden under a sticker
Reply 6 of 18, by TheFriedLemon
could some regulator be soldered on, if yes what type and size?
Reply 7 of 18, by TheFriedLemon
thats what mine already has on it
Reply 8 of 18, by shevalier
For 5v operation, Its mast be looking like that's
Reply 9 of 18, by TheFriedLemon
shevalier wrote on 2024-08-28, 07:45:
what are the markings on the second regulator and capacitor?
Reply 10 of 18, by shevalier
TheFriedLemon wrote on 2024-08-28, 08:23:
1117-3.3 (fixed 3.3v) from any manufacturer (AMS/AMC/NCP/TI/etc)
electrolityc cap - 22-100uF * 10-25V general use
Reply 11 of 18, by TheFriedLemon
shevalier wrote on 2024-08-28, 10:16:
mine has a second cap in the left of the one you said should be moved
Reply 12 of 18, by shevalier
TheFriedLemon wrote on 2024-08-28, 10:27:
I did this a long time ago, I forgot that 1 capacitor is not enough.
Specifically C15 - between the regulators
Capacitor C7 can be left untouched; if you add a regulator, its function becomes redundant.
Requires 2 electrolytic capacitors.
From the PCI bus +5V at the input of the 3.3V regulator
From the output of the regulator 3.3V, the same capacitor will then be at the input of the Vcore regulator (as far as I remember, 1.8V)
When setting the fixed regulator to 3.3V, resistor RY2 must either be shorted with solder, or the 0 resistor (0603 size) must be set.
Resistor L3 (ferrite bead was expensive, so there is a 0 ohm resistor there) must be removed because it is switching a 3.3V power supply
Either from the bus or from the regulator.
C14 and c16 - X5R/X7R 0.1u 10 V, type - 0603.
If your soldering skills are not very good, it is better not to try to solder them. Its are for perfectionism.
Reply 13 of 18, by TheFriedLemon
So all i have to do is:
- Remove the resistor from RY2 and short that connection
- Remove L3
- Move C7 to C13
- Move C37 to C15
- Add a 1117-3.3 regulator in U2
Reply 14 of 18, by shevalier
TheFriedLemon wrote on 2024-08-29, 03:00:
So all i have to do is: - Remove the resistor from RY2 and short that connection - Remove L3 - Move C7 to C13 - Move C37 to C15 […]
- Remove L3
- Move C7 to C13
- Move C37 to C15
- RY2 is empty pads, nothing to remove
- Add C15 22~100u*10~25v electrolytic capacitor
Reply 15 of 18, by TheFriedLemon
shevalier wrote on 2024-08-29, 03:18:
- Remove L3
- Move C7 to C13
- Move C37 to C15
so, i dont touch c37?
Reply 16 of 18, by TheFriedLemon
cause it has a cap on mine
Reply 17 of 18, by shevalier
TheFriedLemon wrote on 2024-08-29, 03:59:
- Remove L3
- Move C7 to C13
- Move C37 to C15
No, its Sil3512 Vcore =1.8V
Reply 18 of 18, by shevalier
TheFriedLemon wrote on 2024-08-29, 04:00:
That's why I replaced it with MLCC 47u*6.3V
But this, again, is perfectionism.
If there is absolutely nothing to do, you can put polymer capacitors there, such as 10u*6.3V.
These are often located near the audio codec on motherboards from 10 years ago.
Re: Audigy 2 ZS Crackle Fix
See pic around 1117 regulator
