First post, by informatyk
- Newbie
I decided to make AT power supply by converting it from regular ATX psu.
I bought rare P8/P9 connectors (it's molex 90331-xx04) and pins. They are the same as the original ones!
Now I need to buy a decent ATX power supply, then I will cut off the 20-pin ATX connector and install P8 and P9 connectors. Green and ground will be connected to a regular AT switch. I know that such a power supply should have -5v, which is hard to find in newer models.
What do you guys think of this power supply?
https://download.marpio.net IE4 compatible retro software download site
