First post, by pskjonte
Hi!
Long time lurker here, just created an account! Great forum!
I am a 41M from Sweden, and been building retro computers and fiddling with old hardware all my adult life.
Now to my little problem...
I have a Pentium 3 build i´ve been struggling to get Windows 98 SE to work properly on.
- Pentium 3 1000MHz
- 512 MB PC133 SDRAM
- Asus CUV4X Motherboard
- Asus GeForce 2 GTS V7700
- Righteous Orchid 3D II, Voodoo 2 12MB
- Soundblaster Live!
- 128 GB mSD Card (Kingston) with reader "GINTOOYUN SD SDHC SDXC MMC" from Amazon
- AOPEN 350W PSU
Other
- C: 10GB Windows 98 SE
- D: 106 GB Games
- No unofficial SP
- DMA Enabled on HD controller
Windows 98 SE install seemed fine in the beginning, installed from OEM disk
The problem consists of intermittent freezing, lag spikes, and sluggish performance sometimes.
When i boot up its 10-15seconds loading time with the pointer. When i click on "control panel" for an exampel, i takes several seconds for it to load.
When i click on the start menu, it justs hangs/lock ups, and then all of a sudden, it comes back to life and open/closes the menu several times.
Sometimes it works without hiccups.
It´s getting worse and worse, so my suspicion is the memory / harddrive (mSD 128gb) or something gets corrupted little by little.
Capacitors on motherboard and hardware looks fine, all in great shape as far as i can tell. Games run slow sometimes, both 2d and 3d titles.
Any suggestions?
Ive tried the following:
- Reinstalled WIN98
- Bought a new CF/mSD adapter
- Changed drivers / direct x
- Dissassembled everything, cleaned.
- BIOS Reset / Changed battery
- Updated BIOS
- Removed every PCI card / DVD ROM
- Swapped memory banks
Last time this happened i ended "rundll32" from task manager and the system became snappy again.
Maybe i can try to do one parition only and change to 256mb ram to see if thats the problem.
Or try a SSD disk instead of a mSD card?
Thank you for suggestions // Jonas, from Sweden
