First post, by Warlord
Hi, I've been on these forums for ahwile. But real life has gotten in the way of things and I just havn't had the time to post anything new.
I've had this case for a few years, and like I explained in another thread, I never had the original hardware. It's also missing the right side skirt and I had to make a IO shield frame holder out of aluminum. Not sure what else to call it. Not the IO shield but the place where you mount one was missing.
I had to rewire all the leds and switches becasue propietary headers, also I needed to make a mod to mount another fan inside.
I think I had around 126 FPS in Crisis at max settings @ 1920x1200 Resolution. Dont quote me I should run the tests again.
Long story short.
I found a computer at a Habitat for Humanity and when I looked inside it was a P8P68 Delux with a 2600k and 32 GB of ram. It was cheap.
I put it in a vintage Intergraph TDZ2000 case and added a EVGA 650 P5 PSU to it.
Bought a GTX Titan X from South korea for $100
Installed an Xfi, I plan replacing later with this Auzentech Prelude I bought recently.
Threw in some noctua and corsair maglev type fans, SSD, BD Rom/burner, USB front Panel and there you have it.
Total cost if I'm being honest is around 400 Dollars US. But mostly the parts I already had. Thats probably what I have in it anyways. I feel ike its really closer to 200 if you only count what I bought recently to put it together.
I plan on adding another SSD I have laying around here and install win 7 and windows 10 on. Also I have a 2TB drive I would like to use.
I might make a custom side panel with a plexy glass window and add a purple/blue LED inside. I haven't decided since this case isn't exacty a museum piece and it doesn't really matter since I don't have the rest of it.
Reply 1 of 9, by Warlord
Shout out to PcBytes who ripped the original TDZ2000 Bios boot logo from 1998 for me. I managed to replace the boot logo of the ASUS board with the Intergraph boot logo that orginally shipped on these machines. So now its a total sleeper.
Reply 2 of 9, by Irinikus
Very Cool!
YouTube
Reply 3 of 9, by PD2JK
Like the workstation look!
Any problems on the internet since it's your daily driver? 😀
has all kinds of stuff
Reply 4 of 9, by Warlord
Thanks, Internet is not really problem right now. A rig like this is powerful enough to run chrome 120 on XP. Both Supermium and Thorium run beautifully. All of those palemoon XP forks run great too.
Reply 5 of 9, by Dualy
I am using similar specced machine as a daily driver with Windows 7. When I got it new in 2011, I originally put XP on it, but it never worked quite right, had some weird issues with system just freezing for a second. But 64-bit Windows 7 worked beautifully ever since.
And yeah it is still powerful enough to run any of the normal office tasks without any issues
Reply 6 of 9, by chinny22
Bit jealous
GTX Titan X and Auzentech are on the list for my Ultimate XP build (although I want a dual socket system)
but I can't justify the cost so had to settle on a pair of GTX950's and X-Fi which is still overkill for my games.
gaming on this will be a blast
Reply 7 of 9, by PcBytes
Warlord wrote on 2024-08-24, 03:07:
Glad I could help. I also found these two on some of the BIOSes. One is from ZX10, the other is from "TD260", according to its BIOS strings.
Reply 8 of 9, by Brawndo
This is a good reminder that I should post my ultimate XP build, which has 3 GTX 580s in tri SLI. I remember those Titan X cards were stupid expensive back in the day, it's hilarious that you can get one for $100 now. I like the workstation look, that's cool!
Reply 9 of 9, by Warlord
I tested the Auzentech a few days ago, and it has some kind of problem. It works but the sound quality is bad, so its added to my bucket list of things to repair someday. Possibly a new opamp for the front LR channels and a recap would fix it.
Looking forward to trying out the other bootlogos pcbytes gave me.
I received one of those artic pwm fan spliters the other day. Plugged it into the CPU fan header and split the PWM signals to all of the fans in the system. This is the only header on the board thats truly programable. The other ones let you monitor and and a couple of them claim you can control fan speed but they don't. Its not a fault of the board its just the chip asus used.
