First post, by MSKino
Does anyone know any media player that doesn't require a CPU with SSE and that can play mp4, mp3, and mkv files?
Reply 1 of 19, by BinaryDemon
I’d probably opt for an older version of VLC.
You didn’t mention which OS you are running. I read VLC 0.84 and lower run on Win9x without KernelEX. If you running something else like 2K, XP, Linux you should be good thru version 2.1. without SSE.
Reply 2 of 19, by tauro
MSKino wrote on 2024-09-04, 18:20:
On Linux you can probably use almost any player, provided it's compiled for the correct architecture. In any case you can compile them yourself.
mplayer/vlc are good options.
Reply 3 of 19, by Repo Man11
I don't think it is possible for a K6-2 to play a .mkv file.
Reply 4 of 19, by rasz_pl
sure it is, .mkv is just a container 😀 you can put a potato in it and it will play.
Fastest K6-2 are around Celeron 400MHz performance level so no full res PAL/NTSC Mpeg2, but 320x240 should be fine.
There should be win32 mplayer builds compiled with full CPU features discovery floating somewhere on the net.
Reply 5 of 19, by BitWrangler
The powerDVD that came with my first DVD ROM played okay on my K6-2@450, it was at like 85-90% CPU load though. The one that came with my Voodoo3 not sure if that was powerDVD or winDVD, that dropped it to 30% CPU load with whatever. I know though that even with all the right codec packs and latest media player for 98 that I couldn't do it on media player though.
Reply 6 of 19, by Repo Man11
rasz_pl wrote on 2024-09-05, 03:12:
I'll take your word for it. I only know that file extension from Blu Ray rips and I know those require a far more powerful CPU.
I have a copy of Power DVD XP that came with a long ago video card purchase. That version of that software has been able to play DVDs on every K6-2 system I've had. The lowest spec system I have it installed on right now is my PCChips M520 with a K6-3+ @ 450 MHz and a PCI FX5200 and DVDs play very well.
Reply 7 of 19, by Disruptor
Repo Man11 wrote on 2024-09-05, 04:03:
Does it support 3DNow! ?
Do old VLC versions or other players support 3DNow! ?
Reply 8 of 19, by BinaryDemon
https://www.3dnow.org/software.shtml
Has a list of common games/software and if 3Dnow is supported - but it looks like it hasn't been updated since AUG 1999.
Neither PowerDVD nor VLC is on it, I think the list predates both.
Reply 9 of 19, by GemCookie
BinaryDemon wrote on 2024-09-04, 22:09:
VLC 1.1.0 did not work on my K6-2 350. It launched, but attempting to play a video made it immediately quit. VLC 0.8.6d was fine.
Gigabyte GA-8I915P Duo Pro | P4 530J | GF 6600 | 2GiB | 120G HDD | 2k/Vista/10/Debian
MSI MS-5169 | K6-2/350 | TNT2 M64 | 384MiB | 120G HDD | DR-/MS-DOS/NT/2k/XP/Gentoo
Dell Precision M6400 | C2D T9600 | FX 2700M | 16GiB | 128G SSD | 2k/Vista/11/Gentoo
Reply 10 of 19, by douglar
BinaryDemon wrote on 2024-09-05, 12:36:
Wow!. Amazing that 3dnow.org is still live. I would have expected it to go the way of amdzone.com a while ago.
Looks like https://www.planet3dnow.de picked up the slack ....
Reply 11 of 19, by MSKino
I am running Windows XP so I'll be trying VLC 2.1, thanks for the info 👍
Reply 12 of 19, by MSKino
Trying to install VLC 2.1 gave me this error
Reply 13 of 19, by MSKino
I got VLC 1.0.0 Goldeneye installed
Reply 14 of 19, by MSKino
GemCookie wrote on 2024-09-05, 13:33:
VLC 0.8.6d also works for me. VLC 1.1.0, 1.0.0, etc crash whenever i try to play a file. But VLC 0.8.6d works fine. 360p mp4 content plays fine, although there are some frame drops.
Reply 15 of 19, by tauro
You would need a relatively new video card with h264 decode acceleration to play modern mp4s smoothly (even at high resolutions).
You can find period-correct video cards that support DVD/MPEG-2 (h262) decode acceleration.
Reply 16 of 19, by BitWrangler
Check it on an overkill fast system, 'coz the lower res mp4/divX stuff might have been encoded long ago with primitive codecs and not quite fast enough CPU and stutters are baked into the file.
Reply 17 of 19, by MSKino
BitWrangler wrote on 2024-09-06, 21:54:
I've played the same mp4 file on my main system running Windows 11, with an amd Ryzen 5 5600X and a GTX 980 Ti. It plays smoothly without any frame drops.
Reply 18 of 19, by MSKino
tauro wrote on 2024-09-06, 21:53:
Alright 👍
Reply 19 of 19, by dr_st
Some version of BSPlayer? I think that's what I used back in the day.
