First post, by Qwseyvnd
Hi to users in Vogons.
Do you know where I can download datasheets which contains logic descriptions with pins? I might visit NXP in Eindhoven in Netherland if they do not having hesitate to give me basic logic chips into the thumb-stick or hard drive or SSD.
Greetings from Øyvind Hagen.
Reply 2 of 3, by Horun
The TI book is a good one, so is the Fairchild: http://www.bitsavers.org/components/fairchild … L_Data_Book.pdf
There is also https://www.alldatasheet.com/ which has datasheets for many newer chips AND you can download them, but they are one-by-one mostly.
Reply 3 of 3, by Qwseyvnd
Horun wrote on 2024-09-09, 00:42:
One-by-one mostly therefore I searching for collect downloadable packaged file. I will double check this book.
