darry wrote on 2024-09-11, 21:34:
If the option ROM path does not pan out, a cheap used low power GPU might be an easier solution, unless you have a specific reason for not wanting a GPU. If this a personal challenge/quest, I understand, but if you just want a working machine, sourcing random PCIE cards to try to find one that might masquerade as a GPU well enough to allow your board to boot seems like it would be more expensive in the long run.
I want to make small dock, and i limited by height of MB - only 65mm, even low profile GPU not working for me well, also its power usage, 10 motherboards + 10 GPUs, its like +10-15% of usage, too much i think, and yes challenge also here.
I didnt knew that MB can have or not this headless mode, if i knew it before, i would buy MSI one, they added this option in to their bios(*see question at the end)
Keep in mind that older GPUs might require a CSM, which your board may or may not have. If it does not have CSM support, a UEFI capable GPU would be needed.
EDIT : A used GT1030 is about 40ish US$ . A GT730 is even less, though some of them will only work with CSM.
I already own old low profile GPU, interesting thing, that i can't access bios, on post & boot stage - monitor is black. I think its exact related to CSM and legacy ROM, which is disabled i think, cause with new GPU everything working well.
**question at the end:
I see that almost all motherboards use same AMI Aptio 5, and as i understand MB manufacturers have customized only view of UEFI, cause exact AMI BIOS which is hidden inside - is closed code, and compiled on AMI side, am i wrong?
I saw like AMIBCP tool, is not public, and available only for MB manufacturers, and there they(AMI) said - you can change menus & view, without compiling bios code, - thats why im thinking that bios is everywhere is same.
What if i just take MSI bios and flash it to Biostar board?
