First post, by mombarak
- Member
Hi everyone,
I have some games, mostly Warcraft 2 and the expansion, which I am trying to use with CD-Audio. I believe it is redband audio or mixed mode. The CDs are the original CDs. When I use Midi, it loops the Midi track. I think that is expected. But CD-Audio always stops at some point and you only hear the sound effects of a game. When using a DOS cd player, I have access to all songs.
I read in some threads and in other forums that this could be a driver problem of CD-ROMs and wanted to check if you have seen similar things? I am using the Teak CD DOS driver because it is the only one I know that can spin down the CD ROM speed so the PC stays nice and quiet.
Do you have some recommendations what to test first? Are there parameters in config.sys or autoexec.bat which I could use or should I try a different driver instead? If so, do you have recommendations?
Thanks a ton in advance.
