First post, by aazard
I do L3 support in Canada and the accounting office on the floors above us, in our building, are moving out.
I "saved" these 6x thin clients just by asking if I could have them (but not the DOMs, they had already been taken by their own IT ppl.)
Looked them up, here they are:
Note: no isa, pci (1x mini pci-e), "non-sb" sound, no game port ... but pretty speedy (1ghz)
HP T5570 (all were 4gb ram)
CPU:
- VIA Nano u3500 @ 1Ghz. Features/flags: see, https://www.parkytowers.me.uk/thin/hp/t5570/
Chipset:
- VIA Technologies, Inc. VX900 (& its features/controllers, I will skip listing) Full list: see, https://www.parkytowers.me.uk/thin/hp/t5570/
- VIA Technologies, Inc. VT82xx/62xx UHCI USB 1.1 Controller (rev a0)
- VIA Technologies, Inc. USB 2.0 (rev 90)
- VIA Technologies, Inc. VX855/VX875/VX900 PCI to PCI Bridge
- Audio device: VIA Technologies, Inc. Device 9170
- Audio device: VIA Technologies, Inc. VT8237A/VT8251 HDA Controller (rev 20)
- Ethernet controller: Broadcom Corporation NetLink BCM57780 Gigabit Ethernet PCIe (rev 01)
RAM:
- 1x SODIMM, DDR3, 8gb max (Bios “sees” 4gb max, 64bit OS will see & use up to 8gb)
IDE/DATA:
- 1x standard 44-pin IDE connector, ATA133, 2x device support (FLASH DOM default goes here)
- 44-pin IDE supports: “44-pin to 40-pin IDE Adapter Converter Cable w/Molex Power (I was able to Run a Master/Slave setup with HDD+ODD)
- This will further support adaptors, for SATA SSD to IDE connection
- 1x SATA2 port 3Gbps, 1x device support (with power connector)
- It is possible to connect THREE (3x) drives, ALL as SATA drives, via adaptors for TWO (2x) drives.
PCI-E:
- 1x PCI-E mini socket (PCI-Express Half Mini Card)
Header:
- 1x 14-pin header, CN5 (GPIO??)
GPU:
- VIA ChromotionHD 2.0 @ 1920 x 1200 32-bit colour , over DVI-I & DVI-D
Network:
- 1x (10/100/1000)
USB:
- 6x (USB2.0)
Serial:
- 1x
Parallel:
- 1x
PS/2
- 2x (KYBD & Mouse)
SBEMU compatibility reports list reports, #36: 2023-03-30 HP T5570T VX900 by stamasd Re: SBEMU: Sound Blaster emulation on AC97: (I have not personally tested)
- “[..] load SBEMU [..] It specifically wants the /i7 parameter to work. When loaded as "SBEMU /i7" it installs itself successfully.“
- “Also the sound volume in all of the games that worked was adequate.”
Test (1 unit only):
Boots off usb, no internal floppy port (but com, ltp1 and usb floppies should work, I dont have one handy to test, other than a usb "sony floppy disk camera")
- Drive adaptors (both on motherboard and on drive connectors) seem to be seen/function "invisibly"
- 120gb IDE HDD + 128gb SSD, 4GB RAM. Installed PC-DOS 7.1 Rev0 BLD134 fine
- Installed Windows 98SE > EDIT = bad > further testing shows I can not locate drivers
- Install Windows 7 + XP mode = fine (8gb test also fine in Win7 x64) - minimal test
- Install Windows 10 (Rufus) = fine (8gb test also fine) - minimal test
- Install Windows 11 (Rufus) = fine 8gb test also fine) - minimal test
Found:
https://youtu.be/XyOdzbkmxQI
https://youtu.be/eCKf7LPDBv0
HP t5300 series 98SE install (also "part" applies to HP t5550/t5565/t5570):
https://youtu.be/8YNCkgMyH6k
Related Github Procedure txt:
https://github.com/cml37/dos-utils/blob/maste … 700_win98se.txt
GPU compare:
dos-backups-v0-uawe884sptod1.png?width=2560&format=png&auto=webp&s=7914b2f4a1689bfb8eba2e97c83b7e79c819db2c
3DMark 2000 & 2001SE:
dos-backups-v0-c428zw6tptod1.png?width=1915&format=png&auto=webp&s=9ab45b2383fda1f3bed61d47425137fa934a0495
Aazard -
Mono Planar Mortal & Unascended Master
Retro Enthusiast & L3 Trouble Shooter
.... Getting old
