First post, by Scottmm
I have a couple boards that I recently took the the AT Keyboard din5 connectors off to try and fix battery damage no keyboard errors. But sadly stress and battery corrosion broke the front gnd pins off.
I know those Pins are just GND pins and used to provide a bit of mechanical stress relief. but are they needed to be connected to provide GND to the keyboard or is the GND from pin 4 enough.
All the DIN5 connectors I see on ebay and Amazon do not appear to have the tin face but do have the pins.
thank you
