Intel 486 DX2 and AGP x2 graphic port
First post, by Tymo486DX2
I am looking for good motherboard for Intel 486 DX-2 66 MHz.
Lot of motherboards on the market. Is there any MB with AGP x2 port?
Standard is with a VESA local bus "VLB". And some of MBs have PCI slots too.
FSB should be 33 MHz for that processor and multipler is "2", gives 66 MHz for CPU.
Special mode for AGP x2 handling could give 66 MHz if AGP is used and release the Host Bus for 33 MHz for CPU and PCI.
I want to use Winfast 3D S800 [8 MB RAM] or VooDoo 3 [16 MB RAM]. AGP x2 versions of these two cards should be better.
Links:
Winfast 3D S800
https://theretroweb.com/expansioncards/s/lead … s800-pci#driver
VooDoo 3 2000
https://theretroweb.com/expansioncards/s/3dfx-voodoo-3-2000
Pictures Winfast 3D S800
Route 66 MHz😎
Reply 1 of 71, by gerwin
Tymo486DX2 wrote on 2024-09-17, 18:11:
That combination does not exist...
https://en.wikipedia.org/wiki/Accelerated_Graphics_Port
The AGP slot first appeared on x86-compatible system boards based on Socket 7 Intel P5 Pentium and Slot 1 P6 Pentium II processors. Intel introduced AGP support with the i440LX Slot 1 chipset on August 26, 1997, and a flood of products followed from all the major system board vendors.[3]
Where it says Socket 7 I would say "Super Socket 7"
https://en.wikipedia.org/wiki/Super_Socket_7
Reply 2 of 71, by BitWrangler
486 didn't have AGP, Pentium Classic didn't have AGP, Pentium MMX boards with Intel chipsets didn't have AGP, Super Socket 7 and Slot 1 got AGP, in between the last two there were not quite super via chipsets that got it VP3 etc, but still 3 generations past 486es.
Then as far as PCI 486 boards go... they're early PCI implementations, not PCI 2.0 which is "getting warm" but not near enough AGP to make it simple.
Even super fast AMD DX5 systems barely take advantage of early 3D accelerators on PCI, so doing anything interesting or useful with an AGP accelerator with a DX2-66 is unlikely. But after you've proved us wrong, do SATA for 286.
Reply 3 of 71, by stamasd
BitWrangler wrote on 2024-09-17, 18:29:
I will aim even higher. SAS3 on 5150, anyone? 😜
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 4 of 71, by Tymo486DX2
So it's a pity, because I would like to buy it. And thank you for your answer.
Route 66 MHz😎
Reply 5 of 71, by Disruptor
Blah blah blah.
I have a 486 with AGP.
Okay, it is on a Matrox G400 behind a PCI-to-AGP bridge.
But you won't benefit from any AGP feature at all on a 486.
Reply 6 of 71, by waterbeesje
Gets me thinking... Agp to PCI bridge and get that onto a 486 board. With that you may even go to a pcie graphics card?
I'd love to see a DX2 with an ati X800
Stuck at 10MHz...
Reply 7 of 71, by BitWrangler
Go all the way, terascale or tesla or something and run an OS on the shaders so you can use the 486 as a DOS coprocessor.
Reply 8 of 71, by dionb
Take a look at PCIe to PCI bridges. They are 3.3V only so you will need to mod the board (or slot, or bridge card) for work in 5V-only PCI on a 486 board, but other than that you can do some pretty insane stuff. Only limit for DOS VGA is that the card needs a VGA BIOS designed to work with BIOS, not UEFI.
Reply 9 of 71, by Many Bothans
As dionb mentioned, you'll run into the whole 5V PCI slot issue on the 486 platform, but check out this thread on AGP-to-PCI adapters - AGP to PCI adapters - any PCB designers here willing to make one?
  • Zenith Z386SX-20, 8MB FPM, Video 7 1024i, Unhoused
  • AOpen AP43, Am5x86-133@160, 1MB L2, 128MB FPM, Stealth III S540 32MB Savage4, SB32
  • ITX-Llama, 3Dfx V3
  • Asus CUV4X-E, P3-933, 512MB PC133, Hercules 3D Prophet II MX 32MB, SB Live!
Reply 10 of 71, by The Serpent Rider
Technically you can get 486 with 66MHz PCI.
Reply 11 of 71, by darry
The Serpent Rider wrote on 2024-09-17, 22:23:
I presume that would imply overclocking a 486DX-50, the motherboard's PCI bus and RAM to 66MHz (unless RAM can be run more slowly on some 486 chipsets ?) AND finding a PCI video card the will run on a 66MHz PCI bus (likely PCI 2.0 and 5V ).
Or is there another way to do this ?
Reply 12 of 71, by Tiido
Common way is a specific 486 motheboard (I think it was a Biostar but my memory is hazy) and using Cyrix or AMD 5x86 with 2x multiplier. Finding a video card that takes 66MHz PCI is probably a challenge.
Reply 13 of 71, by darry
Tiido wrote on 2024-09-17, 23:41:
Yes, I had forgotten about those, thank you.
Probably a SIS496 chipset, I'm guessing.
I wonder if a PCI 2.1, 66MHz capable video card would work on a PCI 2.0 bus overclocked to 66MHz.
Reply 14 of 71, by The Serpent Rider
Matrox Millennium II and Voodoo 3 are working.
Reply 15 of 71, by Tymo486DX2
The conclusion is that there could be a board for the 486 DX2 with an AGP x2 port manufacturer's version all on the board. Should we pray for it or give it up?
New boards for 486 a small batch for hobbyists, would there be a demand for it because I'm still in favor of it.😀😀😀
Route 66 MHz😎
Reply 16 of 71, by BitWrangler
Watch this space and fork it for an AGP version I guess...
https://github.com/skiselev/sandy_river_486
Don't be under the impression it will be cheap though. $250 would be probably the middle of the range, plus or minus a lot.
Reply 17 of 71, by Tymo486DX2
If we overclock the FSB, including PCI, to 66 MHz, the clock of 486 DX2 will increase unnecessarily to this value. We need better interface clocks and modes for PCI and AGPx2 activited separately, including a fixed speed in the CPU socket of 33 MHz. If AGPx2 mode is active then 66 MHz. Dynamically switchable. Regular PCI-to-AGP bridge can only work as AGPx1 at 33 MHz only for 486 DX2.
Route 66 MHz😎
Reply 18 of 71, by Tymo486DX2
BitWrangler wrote on 2024-09-18, 12:23:
Something would be possible.
And what to prepare such a MB design, collect orders for such an MB into a list of willing and waiting people and order?
Route 66 MHz😎
Reply 19 of 71, by Tymo486DX2
Socket PGA168 for 486 DX2 link
4x 72-pin EDO-RAM
1x AGPx2 at 66 MHz
2x PCI at 33 MHz
2x ISA
1x VESA VLB
cache memory 2 MB
integrated Multi I/O controller with 2xIDE
FSB 33/66 MHz dynamic
Chipset Intel 440 BX for pentium II and slot-1 was very nice.
Host Bus all at 66 MHz, PCI stable on 33 MHz, CPU 486 DX-2 could be too, AGPx2 as native Host Bus at 66 MHz. Quite simple and nice.
Route 66 MHz😎
