Coprocessor problem
First post, by daniil1909
Recently, i posted about 386 stuck at wait. I fixed it by removing coprocessor or by just disabling fpu test in bios (but dos refuses to work), so is it coprocessor or motherboard trouble? (i am really afraid). My m/b is seritech 386 ad iii
Reply 1 of 21, by dominusprog
Well, are you sure about the FPU being healthy?
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 21, by daniil1909
dominusprog wrote on 2024-09-20, 10:12:
Not sure, its missing one leg and after removing pc boots normally.
Reply 3 of 21, by daniil1909
after hard reset pc boots and passes fpu tests (with fpu) but in first start (before reset) it stuck at wait
Reply 4 of 21, by dominusprog
Which pin is it? Can't you solder a piece of wire on to it?
Reply 5 of 21, by daniil1909
dominusprog wrote on 2024-09-20, 10:53:
i dont think so as i dont really can solder those tiny pins. I dont have such small soldering iron
Reply 6 of 21, by daniil1909
pin is left upper (first row of pins)
Reply 7 of 21, by dominusprog
Insert a piece of wire into the socket, cut the top and install the FPU.
Reply 10 of 21, by dominusprog
Can you post a photo of the FPU?
Reply 12 of 21, by dominusprog
Add a little bit of solder to the broken pin and try again. Also use a contact cleaner on the socket.
Reply 13 of 21, by Disruptor
You may have luck when a resistors leg fits into your FPU socket. They use to have enough stiffness.
Then you may cut a bit off and solder it on that pin. It should have same length than your other pins.
Reply 14 of 21, by daniil1909
I think fpu is just broken because previous owner programming using cos and sin. Maybe he sell this for cheap because of fpu as he need it
Reply 15 of 21, by daniil1909
i replaced missing leg with solder, finally, after 1 hour...
Reply 16 of 21, by Horun
daniil1909 wrote on 2024-09-20, 10:17:
.... its missing one leg and after removing pc boots normally.
daniil1909 wrote on 2024-09-21, 04:05:
OK. Does the FPU work now?
So the board works fine without it. Do you need an FPU ?
The motherboard working proper is main thing, everything else added is secondary IMHO.
Reply 17 of 21, by wierd_w
A modern alternative to old bits of resistor leg might be a small cutting of "beading wire" from the crafts aisle at your local supermarket.
I picked up a roll of sterling silver plated copper wire for this exact kind of thing. The silver plating is sterling type (so does not tarnish much), and VERY accepting of being solder-tinned. It's stiff enough for most functions like this, and works great as jumper wire. Available in a wide assortment of gauges.
Only downside is that there is no insulation, so dont use it as bodge wire unless you are very good at applying soldermask or something to the naked wire before running it. It's great for correcting damaged traces though.
(Example of the stuff in question)
https://www.amazon.com/20-Gauge-Resistant-Sup … ref=sr_1_1_sspa
Reply 18 of 21, by daniil1909
Horun wrote on 2024-09-21, 04:32:
OK. Does the FPU work now? So the board works fine without it. Do you need an FPU ? The motherboard working proper is main th […]
No. FPU is getting hot as hell
Reply 19 of 21, by daniil1909
wierd_w wrote on 2024-09-21, 07:46:
A modern alternative to old bits of resistor leg might be a small cutting of "beading wire" from the crafts aisle at your local […]
Yeah i had something like this by cutting an pin from wire. It doesn't solder, just fall out
