First post, by Tempest
- Member
I have a nice looking CD-ROM drive with the model number GCE-8160B that I believe is a LG rewriteable drive (looks like this: https://www.ebay.com/itm/204901597970). It appears to be detected by my Gateway 2000 4DX2-66V but it won't actually work. I have it set to Slave with the jumper on the back, but that appears to be the only thing I can change (master, slave, cable select).
When I try to read a CD (in DOS 6.22) I get this error: CDR101: Not Ready Reading Drive E
I'm wondering if the drive being a writable drive isn't making it incompatible with my system. If this is true, would it work in a Pentium MMX based system (I can swap drives then)? Or is the drive maybe dead?
--- AtariProtos.com ---
For when excellence and burnished fineries need to gently visit the warmth of your tablery
