Identify this RAM
Reply 20 of 21, by mkarcher
rasz_pl wrote on 2024-09-25, 21:28:
dionb wrote on 2024-09-25, 10:52:
Your So7 board should tell you at POST what kind of RAM is in there, otherwise run a tool on that system that tells you.
Can you name motherboard or a software tool that will be able to differentiate between EDO and FPM using software detection?
Nearly every Intel 430 board with Award BIOS should show the memory type in the "system configuration" box. Random YouTube link with that box. Note the "Bank 0 EDO DRAM" and "Bank 1 EDO DRAM" items in the bottom right part.
Reply 21 of 21, by rasz_pl
mkarcher wrote on 2024-09-25, 21:34:
minor brain aneurysm 😐 Cant directly check ram type, but can check what mode is ram controller running in.
