Reply 28440 of 31007, by BitWrangler
- l33t++
Doing some "brain callibration" for the desktop console case I picked up for a song yesterday. I think this size will run you $60 to $70 normally. If you want one, I think best search terms are "sloped instrument console" or something like that. This one is 14"x 11" at the base internal, and 2 15/16" high at back, somewhere about an inch at front. These style of enclosures have been around since at least the late 60s, such that through the 70s, homebrew 8 bit enthusiasts may have built terminals, TV typewriters (RIP DL) and even whole computers into them. Anyway they have a very trans decade vibe to me, 70s into 80s, the 2 years either side I guess.
So with just grabbing what stuff was convenient to get an idea of what could get in there, there's some super rough mockups of what might transpire. I might have a keyboard that goes edge to edge too.
Undecided on it's final form, and whether it will have floppy or optical, or SSD or spindle (Don't so much like "wasting" SSD on anything below 500mhz). Tentative thoughts are a K8N800 s754 board with Athlon 3000+ and then it will run an Amiga em decently, and em basically everything older than late 90s. Wondering also about persevering with unichrome for only dx 5,6,7 or getting a card with riser to sit flat which will do 98 and glide wrappers. Also got an LPX 486 board with a lot on board, but I'll have wayyy too many 486 machines then.
Anyhoo, just a bit of a brain exercise so far, let me think about what fits.... BTW if you find a square footprint instrument console with a 30 degree or so slope, it looks the same proportions as a Lego Space computer block.
edit: Did I mean a K8M800? ... Other options I am thinking, power has gotta be lowish. Athlon 64 3000+ is only 35W. Don't think I've got anything low enough in C2D class, s478 I have a p4M, but that doesn't make more sense than the A64. If I wanted overkill, I've got a haswell i5-4590T which is low watt, but think I want the haswell board for something else, so unless another appears that's not likely. Going the other way, got an atom itx, meh, can do duron or celeron, but those are too similar to the other two projects, Dustin and Derpy, K6-III+ is a mayyybe, but boards available wouldn't really let it stretch it's legs much. However, that does maybe suggest fanless, all passive cooling, which that would maybe do, or a winchip. At that performance it's native dos and 8 bit emu only. Then below that 486 lpx, then some sucky 386/25 NEC powermate board.... then don't think there's anything between that and a custom breadboarded 8086 thing based on some weird crap I have., then ditto 8085s or 6502, 6800 kinda homebrew stuff, but I've got a CoCo2 which I oughta mess with instead... so plenty "up in the air"
