Best cpu for Voodoo Banshee
Reply 20 of 26, by rain
soggi wrote on 2024-10-01, 02:11:
But not AGP Banshee, as most P4 boards will fry the card (and maybe some other parts) in the worst case. […]
rain wrote on 2024-09-28, 17:35:
Pentium 2 with banshee very slow with carmageddon2 .
pentium 3 better
but pentium 4 best
and sorry for adding another post to (useless) necro posts.
kind regards
soggi
using pentium 4 with universal agp slot is it dangerous too ?
Reply 21 of 26, by subhuman@xgtx
stamasd wrote on 2024-09-30, 18:39:
My Banshee runs... well not at all because I can't remember in which storage box I put it. 😜 But when I was testing it, it was with a P2-400 and I was not impressed.
Not surprised, though!
For all intents and purposes, it's a slower Voodoo3 with a single TMU and lower core clock.
Reply 22 of 26, by havli
rain wrote on 2024-10-01, 07:46:
As long as you have board with one of the 3.3V AGP capable chipset, it should be fine. For examle SiS 645/650/651 series and VIA P4M266(A)/P4X266(A). If the board manual specifically states AGP 2x support, even better.
Just beware, there might be boards with universal AGP slot that are not compatible.
These are the ones I tested myself and they are AGP 2x capable.
MSI 645 Ultra
Asus P4S333
ECS P4S5A-DX+
Abit SD7-533
Gigabyte GA-8SIMLH-P
Reply 23 of 26, by Intel486dx33
My Voodoo Banshee cards are AGP
I have tried them with AMD K6 and Pentium 233mhz thru Pentium-III @ 1.4ghz.
They work fine with Any CPU.
Work good with Win98 not sure about Win95
But it is VERY Important you use the Right drivers.
I used the drivers CD from Vogons library.
Link:
http://www.vogonsdrivers.com/index.php?catid=12
Reply 24 of 26, by leileilol
havli wrote on 2024-10-01, 14:53:
Asus P4S333
as much as I love this board, it's also a scary board to me and i've never placed an AGP2X card in there. The oldest card it's seen was a Rage128 Pro
Reply 25 of 26, by soggi
As long as you have board with one of the 3.3V AGP capable chipset, it should be fine. For examle SiS 645/650/651 series and VIA […]
MSI 645 Ultra
Asus P4S333
ECS P4S5A-DX+
Abit SD7-533
As havli partly already said - it could be...there are boards which have a Universal AGP Slot but only support 4x or 4x/8x - f.e. a i875P Board with such a slot (if it exists) for sure doesn't support AGP 3dfx cards (except some rare AGP 4x cards).
A list of boards supporting AGP Voodoos could be found on VoodooAlert forums (German) -> https://www.voodooalert.de/board/forum/index. … ten-mainboards/ (beware: red is untested, light blue tested).
Always be careful when putting an AGP 1.0 (1x/2x) card to socket 423/478 and higher Intel boards and socket A (462) with later chipsets (all nVidia, VIA KT333+ [KT333CF=KT400!!!], SiS 746+, ALi?) and higher AMD boards! This doesn't only apply to 3dfx Voodoo AGP cards.
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
Reply 26 of 26, by havli
leileilol wrote on 2024-10-02, 02:09:
Asus P4S333
I understand, but as a coincidence, this is the exact board I used for testing all kinds of AGP 3.3V cards. Riva 128, TNT, Rage Pro, Banshee, Voodoo3 and maybe others that I don't remember. The only card that doesn't run properly on this board is Rage Fury MAXX - most likely due to chipset incompatibility.
Here is Banshee result and a photo.
https://hwbot.org/submission/2348408
