Reply 20 of 42, by Jo22
- l33t++
^Going with Windows 98SE on the internet is akin to passing through the rain-forest while being fully naked. Sure, you can technically do that, but.. Oh well, never mind. 😅
All I can say is that the threats from the internet didn't decline, but increase in the following years after the year 2000. At home, we also had Windows 98SE on-line in early 2000s, via dial-up.
But I do admit it was via T-Online gateway, which was a bit special due to it's BTX past and the T-Online software. Not a typical ISP experience. More like AOL experience.
We had used Windows 98SE simply because it was the latest OS available at the time, before XP was available. Windows 2000 Workstation did exist, but wasn't meant for home use, as the name suggests.
Also, there are (were) "drive-by infections". I remember them. You didn't have to open an e-mail attachment or do visit a naughty website to get infected.
Back in the day, I was visiting ordinary websites when the guard of H&B EDV's AntiVir (aka Avira Antivir) was suddenly intercepting, telling you which file had just been deposited on your PC.
It happened on both OSes, 98SE and XP. An anti-virus program was really important back then, even though I know of people who claimed they didn't need one.
The main difference was that Windows 98SE had no self-defense built-in. No firewall, no system restore, nothing like this. It's like a tourist with a Hawaii shirt and sandals, when XP is wearing knight armor.
On Windows 9x, the memory protection is much less strong than on the NT line. Windows XP had the ability to restore DLLs from DLL cache if they had been modified.
- Which it normally did if you play around in Windows folder. So normal malware without XP in mind perhaps did fail here. Back in the day. XP SP1 had gotten a simple firewall, too.
So yeah, Windows 98SE is not safe in its own right. The protection that happens through NAT, firewall and IP filters is the work of another system. Router, hw firewall etc.
And that's not how it should be, I think. Depending on someone else to care of everything isn't exactly responsible. But that's just me, maybe.
That's why I also tried to make things reasonably safe by installing the Kerio firewall software back then (+AntiVir). To give Windows 98SE the ability to filter ports, to block them.
Unfortunately, it didn't work. I'm still wondering to this day why the software didn't fulfill its purpose. I just remember checking all settings back then and that I didn't find a mistake. 🤷
The experience I had on Windows 98SE when I upgraded that persons PC in mid-late 200s was about the same one I had on Windows XP a few years earlier, all in all:
A few seconds after establishing the internet connection, the damage was done. And it happened repeatedly, over and over again, not just once. 🙁
With the one difference being that Sasser did merely shut down the XP system via remote command and that SP2 fixed the vulnerability later on.
No idea what Windows 98SE got as a "present" back then, however. 🤷
But anyhow, dial-up connections have become rare these days, that's right. But the danger isn't gone just because of this change. Cable modems and DSL modems not always have a router capability.
Here in Germany the usually do have router capabilities by default, of course, because Fritzbox systems are the reference for years and do have it enabled by default.
Along with them having TAE ports by default for using analogue modems (VOIP), a feature which also isn't exactly the norm. Some even have ISDN ports (S0 bus), to attach digital ISDN-based hi-quality phones, fax machines etc.
By contrast, in other places around globe, some cable modems and DSL modems are exposing the PC directly to the internet. Or did, at one point. Just like dial-up connection used to do.
But there's another threat, maybe; many DSL/cable routers do have a pass-through feature that can be enabled, in which they act like an non-intelligent modem.
It's being used when the cable or DSL user wants to use its own router, but the ISP or homeowner refuses to give physical access to the internet cable.
In such a situation, the router does not do much processing anymore, but simply sends/receives packets. Edited.
Good night. 😴
