First post, by yeokm1
Thought to share my experiment in running MS-DOS 6.22 on a modern system with the latest parts. Got networking working using Xircom Parallel Port network adapter and SBEMU works well on onboard sound chip.
Specs:
AMD Ryzen 5 7600 3.8 GHz
Asus Dual GeForce RTX 4060 Ti EVO OC 16GB
64GB DDR5-5600
Video: https://www.youtube.com/watch?v=yVtC54Ax3AU
Blog post: https://yeokhengmeng.com/2024/10/modern-pc-vintage-twist/
Reply 1 of 6, by myne
Gotta admit, if I knew how to code vxds, I'd be tempted to try making 9x drivers for modern cards.
I built:
Reply 2 of 6, by ludicrous_peridot
It's interesting what performane rating you get with MBF 2.04 running in high resolution (the demo benchmark I mean). Also from the photo you seem to be running an impressive array of beige diskette drives. 😉 Where does the floppy on the front panel plug into among all those new shiny boxes?
GA-G41M-Combo G41/ICH7 - Core 2 Quad Q9550 - DDR3 1033 - Radeon RX570 - CMI-8738 - X3MB (Buran)
Beetle/M/i815+ICH2 - Celeron 566Mhz - Opti 924
https://archive.org/details/peridot-26
Reply 3 of 6, by yeokm1
myne wrote on 2024-10-07, 03:12:
May be challenging as you may not have the documentation of the modern cards.
Reply 4 of 6, by yeokm1
ludicrous_peridot wrote on 2024-10-07, 17:25:
I did a check based on your suggestion.
"Timed 3836 gametics in 131 realtics = 1024.9 frames per second" according to the bench script. It was so quick that it ended before I knew it even started. 😂
I only have one 3.5" floppy drive. I used a USB adapter to convert the 34-pin floppy interface to the USB interface. Then I connect it to the motherboard’s internal USB 2.0 header. I have a photo of that in my blog post.
Reply 5 of 6, by wbahnassi
Nvidia cards dropped support for many modes a very long time ago. You won't be able to run any CGA/EGA game, not even VGA games like Gods. Only basic VGA. And the card doesn't give the monitor the correct aspect ratio, so on a 16:9 monitor you will get a stretched image. I would use a cheap Ati Rage 2XL as it has much better compat, and it can work via a PCIX to PCI bridge. It even has Win3.1 drivers.
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
Reply 6 of 6, by yeokm1
wbahnassi wrote on 2024-10-08, 08:42:
Yes you are correct. I did mention in my blog post that brief tests with other VESA modes and resolutions didn’t work so well. I will edit it to be clearer about CGA/EGA. In this example, I used a 5:4 monitor and the graphics card sized many games relatively well to match the monitor's native 5:4 resolution.
This is just for a fun experiment. I have other more period-correct vintage machines for my actual retro usage.
